Stellantis (Dodge) Tuning and Diagnostic Support
Chrysler, Dodge, Jeep, and RAM Tuning
The legendary Mopar lineup of muscle cars, trucks, SUVs, and off-road vehicles is no stranger to HP Tuners. As one of our most widely supported platforms, HP Tuners offers the best scanning, logging, and calibration solutions for Chrysler, Dodge, Jeep, and RAM vehicles with the MPVI4 devices and VCM Suite software.
Our tuning and diagnostic tools work for every type of Mopar build, whether it’s for better off-road performance with your Jeep Wrangler, faster times on the drag strip or track with your Challenger, or simply achieving better fuel economy with your daily-drivable truck, SUV, or streetcar. Once you’ve made your custom calibration on VCM Editor, use VCM Scanner to monitor performance, data log, and scan for DCTs and fault codes. If you own a 2018+ Chrysler, Dodge, Jeep, & RAM vehicle, grab our Dodge Smart Access Cable to enable read, write, and special functions. For all 2015+ Chrysler, Dodge, Jeep, & RAM, make sure you purchase a NEW upgraded PCM that’s ready for tuning (see below for notes).
We also have EcoDiesel support for select vehicles and TCM tuning support for the 13-20 ZF8HP 8- speed transmission, the 18-21 ZF8HP2 8- speed transmission, the 14-18 ZF9HP 9-speed transmission, and the 07-09 Dodge Ram 2500 Cummins transmission.
Stellantis (Dodge) Tuning Features Include:
- The Dodge Upgraded PCM Purchase is required to tune your 2015+ Dodge/Chrysler/Jeep/RAM (All FCA models, except the 2015+ Dodge Viper).
- Smart Access Cable is required to read, write, and access special functions on 2018+ Chrysler, Dodge, Jeep, & RAM vehicles.
- TCM tuning support for select Chrysler, Dodge, Jeep, and RAM transmissions.
- EcoDiesel support for several Chrysler, Dodge, Jeep, and RAM vehicles.
- Custom tune flashing and high-speed data logging via the MPVI4 tools and VCM Suite software.
- Scan engine codes with VCM Scanner.
Complete list of supported Stellantis (Dodge) vehicles:
| Year | Model Type | Single Vehicle Dodge or Universal Credits Credit cost shown is for ECM licensing only. Additional supported controllers require separate credit cost/licensing. |
| 05-231 | 300/300C 2.7, 3.5, 3.6, 5.7, 6.1, 6.4 |
2 |
| 07-09 | Aspen 3.7, 4.7, 5.7 | 2 |
| 07-08 | Pacifica 4.0 | 2 |
| 17-231 | Pacifica 3.6 |
2 |
| 03-05 | PT Cruiser GT 2.4* | 2 |
| 06-07 | PT Cruiser GT 2.4 | 2 |
| 04-10 | Sebring 2.7, 3.5 | 2 |
| 07-10 | Sebring 2.0, 2.4 | 2 |
| 05-161 | Town & Country 3.3, 3.6, 3.8, 4.0 |
2 |
MPVI4 Vehicle Compatibility Notice
There are a few select controllers that are NOT supported by MPVI4 yet, including Mopar JTEC, JTEC+, JTEC+B, and NGC3. Please view the complete year/make/model list to confirm if your vehicle is not supported before purchasing MPVI4. If you have questions, please contact us.- Vehicles that are only supported by MPVI2, MPVI2+, MPVI3, and MPVI4 interfaces are identified below by a (2) after the vehicle model type.
- Vehicles that are only supported by MPVI4 interfaces are identified below by a (4) after the vehicle model type.
- 1Note: 2015+ Dodge/Chrysler/Jeep/RAM vehicles need the Dodge PCM Service to upgrade the PCM before tuning.
- 3Note: Some PT Cruiser GT, Neon SRT-4, and early 2000s Dodge Ram/Dodge Durango applications use an NGC1 ecm which are not supported, verify what ecm your vehicle uses before ordering.
EMISSIONS DRIVE CYCLES IN VCM SCANNER
Our hardware and software are designed to bring vehicles into emissions compliance and maintain compliance over their lifetime. When tuning your Stellantis (Dodge) vehicle, take advantage of emission Drive Cycles tests in VCM Scanner (v4.13+), like Highway Fuel Economy (HWFE), SFTP-SC03, and select European Drive Cycles to ensure your compliance and test your vehicle’s fuel economy.
Highway Fuel Economy (HWFE) – Test your light-duty vehicle’s highway fuel economy rating.
SFTP-SC03 – Test your vehicle’s exhaust emissions and on-road fuel economy rating when using air conditioning (A/C).
European Drive Cycles – European tests for emissions and fuel consumption.
New Dodge GPEC5 PCM Tuning Support!
HP Tuners is proud to be first-to-market with custom tuning support for several Dodge models equipped with the GPEC5 PCM via our new upgrade service. Plus, tune your ZF8 transmission too!
Supported models:
- 2023-2024 RAM 1500 5.7L eTorque
- 2022-2024 Jeep Wrangler 3.6L
- 2021-2024 Jeep Gladiator 3.6L
Everything you need to tune your Dodge GPEC5 vehicle:
- Upgrade your PCM via our Dodge PCM Service – GPEC5.
- Requires the 2018+ Dodge Smart Access Cable to enable read, write, and special functions.
- Compatible with MPVI3 devices only.
- License your PCM for (4) Universal Credits and your TCM for (4) Universal Credits.
Get Started Tuning
Check out these additional tools that may be required to get started tuning your Stellantis (Dodge) vehicle.
Smart Access Cable
Ready to start tuning? Get your Dodge Smart Access cable that enables read and write capabilities, and special functions for your 2018+ Dodge, Jeep, RAM, and Chrysler vehicles (required for tuning).
Dodge PCM Services
For all 2015+ Dodge, Jeep, RAM, and Chrysler vehicles, our Dodge PCM Upgrade Service is required for tuning. This service upgrades the PCM so you can read, edit, and write a custom tune to your vehicle.
After purchasing this service, simply send us your original or spare Dodge PCM and an HP Tuners engineer will upgrade your module so it’s ready for tuning with VCM Suite.
Diesel Switch for Cummins CM2450 and CM2350
If you’ve ever wanted to switch between your custom maps on the go, Diesel Switch and our Switch on the Fly OS lets you power up from a stock calibration to one of five custom maps with the turn of a dial. Easily mount this aluminum switch knob in your truck’s cabin so you can be prepared for every driving/towing situation you encounter.
THE LEGACY CONTINUES
Take control of your vehicle’s performance and reliability with the new MPVI4 interface by HP Tuners. Use MPVI4 and VCM Suite to data log, scan, read, and write to any supported Stellantis (Dodge) model.
