SCAN, LOG, DIAGNOSE
VCM Scanner, the most powerful and comprehensive OBDII scanning and diagnostic tool.
Connect > Read > Edit > Write > Drive.
Package VCM Scanner with MPVI2 and you have the most powerful and comprehensive scan tool on the market. View, chart, and log diagnostic data in real time via the vehicle’s OBDII diagnostic data port. View and clear vehicle Diagnostic Trouble Codes (DTCs) along with other vehicle module information. Command control functions like closed loop, fans, gear select, timing, air fuel ratio and so much more all in real time. No editor package can be considered complete without comprehensive scan tool capabilities.
TECHNICAL SPECIFICATIONS
- Powerful User Interface
- Fastest most feature rich OBD scanning tool on the market
- Variable Logging/Playback speeds or user controlled using the chart display
- Export feature allows you to view/modify your file via Microsoft Excel (.CSV)
- Customizable histograms
- Histogram user defined filters
- Histogram cell count filter
- Printable histograms
- Customizable gauge display
- Customizable chart
- Separate gauge and chart displays
- Sensor based configuration support
- Installs with default histograms loaded
- Installs in ready-to-scan configuration
- Installs with additional histograms
- User defined PIDs with complex function support (Example)
- MPIDS (Memory PIDs / Manufacturer Specific Parameters) supported
- View and clear DTCs in just seconds (not supported on all vehicles)
- View readiness test status (not supported on all vehicles)
- Change histogram while scanning
- Change charts while scanning
- Change gauges while scanning
- Change unit value while scanning
- Change config files while scanning
- Copy/Paste special between VCM Scanner and VCM Editor
- User inputted markers and comments
- Log comment section to give commentary for future viewing
- VCM Controls for multiple vehicle manufactures, see here for support list
- Case Learn Feature
The MPVI2+ comes packaged with VCM Editor and VCM Scanner and programming/USB cables, making up the essentials of VCM Suite, bringing you one of the most powerful and inclusive scanning, diagnostic, logging and calibration products on the market. Not to mention full support for our latest rendition of Track Addict, whether you frequent the drag strip, circuit, autocross or off-road the MPVI2+ has the fastest scanning, logging and data transmission rates to ensure you capture everything.
