RAM CM2450B ECM Service
$1,499.99
HP Tuners offers two ways to upgrade supported RAM CM2450B ECMs for tuning with VCM Suite.
Eligible 2022-2024 RAM trucks can now receive a Direct OBDII Upgrade through an authorized HP Tuners reseller without removing or shipping the ECM. This one-time send-in service remains available for customers who prefer to have their original ECM upgraded by HP Tuners.
Shipping address for send-in ECM services: HP Tuners (ATT: RAM CM2450B ECM Service) 711 Dartmouth Lane, Buffalo Grove, IL 60089
Out of stock
Get Your RAM 6.7L Cummins Ready for Tuning
HP Tuners delivers full custom diagnostics and tuning support in VCM Suite for RAM trucks equipped with the CM2450B ECM, bringing professional-grade control to modern diesel platforms.
These controllers can be found in the following supported vehicles:
- 2022–2024 RAM 2500 6.7L Cummins
- 2022–2024 RAM 3500 6.7L Cummins
- 2022–2024 RAM 4500 6.7L Cummins
- 2022–2024 RAM 5500 6.7L Cummins
Don’t see your vehicle? Check out our other supported platforms for additional applications.
Transmission Support (Optional)
Some supported vehicles equipped with the Aisin AS69RC transmission may also include the AS69RC_B TCM. Calibration access requires (4) additional Universal Credits per TCM.
The Details
This one-time service upgrades an original CM2450B ECM and is required for tuning using HP Tuners’ software.
Users must physically remove their original ECM from their vehicle and ship it to HP Tuners’ headquarters for servicing. Once upgraded, users have full access to calibrate, log, and scan via the OBDII port.
Note: No IMMO relearn, crank relearn, or “Replace ECM” function in VCM Scanner is required as long as the ECM returns to the same vehicle it came from.
Everything you need to tune your CM2450B ECM vehicle with HP Tuners:
- This one-time, send-in upgrade service.
- Purchase the 2018+ Dodge Smart Access Cable to enable read, write, and special features.
- Download the latest version of VCM Suite BETA for free here.
- Once upgraded, purchase (6) Universal Credits to license your ECM.
- This support is only compatible with our MPVI3 or MPVI4 interface.
- Upgrade to MPVI4.
- MPVI2, and MPVI2+ devices are NOT compatible with this support. Only MPVI3 or MPVI4 devices are compatible.
- While the stock ECM is being serviced at HP Tuners, a spare ECM cannot be temporarily installed and relearned in the vehicle.
- Once upgraded, users must license their ECM. Universal credits sold separately.
- Upon reinstallation, we recommend connecting to the latest version of VCM Scanner and reading/clearing DTCs.
- No other tuning or calibration tools can be used with the ECM.
- Dealer diagnostic tools and VCM Scanner will continue to function normally.
- The latest version of VCM Suite can be used to return to stock calibration and/or update to the latest stock calibration.
Step 1: Confirm your vehicle’s support and purchase this upgrade service. Ensure you have an MPVI3 or MPVI4 interface and 2018+ Dodge Smart Access Cable.
Step 2: After placing your order, download and complete the shipping form found under the “Shipping” tab. Place the form inside your shipping box.
Step 3: Remove your ECM and package it safely with the completed shipping form.
Step 4: Write your order number clearly on the outside of the shipping box.
Step 5: Ship your ECM to HP Tuners using any carrier of your choice. Shipping costs to HP Tuners are the responsibility of the customer.
Step 6: HP Tuners upgrades your ECM for tuning and diagnostics and ships it back to you.
Step 7: Reinstall your upgraded ECM, purchase and apply Universal Credits, and begin tuning using your interface and VCM Suite BETA.
Send your ECM to the following shipping address:
HP Tuners, LLC
711 Dartmouth Lane
  NOTE: Any hardware ordered with this product will be shipped along with your upgraded ECM. To avoid any delays should you require other hardware soon, please order that hardware separately.
- These ECM/PCM/TCM services are completed at the owner’s risk. HP Tuners will not be responsible for the vehicle, its powertrain, or electronics, nor how the control module is used, calibrated, and its functionality.
- Due to the factory location of the ECM in the vehicle, all ECMs will exhibit signs of weathering and wear, which is completely normal.
- When utilizing this service there is a possibility that the vehicle will need to be sent to the dealers to be re synced. Purchaser accepts all liability for this activity.
Should you experience any issues with your ECM, please submit a ticket to our support team for assistance on how to proceed.
