GM E90 ECM Service (Global B)
Original price was: $799.99.$499.99Current price is: $499.99.
HP Tuners is thrilled to offer custom tuning support for the GM Global B E90 ECM found in select GM vehicles (see vehicle list below). This one-time, send-in upgrade service is required to enable diagnostics and tuning capabilities.
Shipping address for send-in E90 ECM service (Global B): HP Tuners (ATT: GM E90 ECM Service [Global B]), 700 Eastwood Ln, Buffalo Grove, IL 60089
Get Your GM E90 ECM-Equipped Truck/SUV Ready for Tuning
HP Tuners is excited to offer full custom diagnostics and tuning support in VCM Suite (BETA) for GM’s Global B E90 ECM. This controller can be found in the following supported vehicles:
- 2022.5-2025 GMC Sierra 1500 5.3L and 6.2L V8
- 2022.5-2025 Chevrolet Silverado 1500 5.3L and 6.2L V8
- 2021-2025 GMC Yukon/Yukon XL 5.3L and 6.2L V8
- 2021-2025 Chevrolet Suburban/Tahoe 5.3L and 6.2L V8
- 2021-2025 Cadillac Escalade 6.2L V8
Don’t see your vehicle? Check out our services for GM’s non-Global B E90 ECM here.
The Details
This one-time service upgrades an original E90 ECM (Global B generation only) and is required to enable tuning capabilities in VCM Suite. Users must physically remove their original E90 ECM from their vehicle and ship it to HP Tuners’ headquarters for servicing (shipping information below). Once upgraded and licensed, users have full access to calibrate, log, and scan directly via the OBDII port.
Note: No need for an IMMO Relearn, Crank Relearn, or to perform the “Replace ECM” Function in VCM Scanner on the stock ECM.
Everything you need to tune your E90 ECM vehicle with HP Tuners:
- This one-time, send-in GM E90 ECM Service (Global B) (upgrade service).
- Download the latest version of VCM Suite BETA for free here.
- Once upgraded, purchase (8) Universal Credits to license your E90 ECM/vehicle.
- GM Global B vehicle support is only compatible with our MPVI3 or MPVI4 interface.
Note: HP Tuners also supports the GM Global B T93 TCM found in some supported vehicles with the E90 ECM and 10-speed automatic transmission. See our GM T93 TCM Service (Global B) here. Email [email protected] to check if your E90 ECM vehicle also has a supported T93 TCM.
- Your upgraded E90 ECM can only be tuned via the OBDII port with an MPVI3 or MPVI4 interface and the latest version of VCM Suite (BETA) (MPV2+ and older generation devices are not compatible with any GM Global B vehicle support).
- While the stock ECM is being serviced at HP Tuners, a spare ECM cannot be temporarily installed and relearned in the vehicle otherwise the stock (now upgraded) ECM that was sent in for service will no longer function in vehicle.
- Once the upgrade is complete, users must license their ECM for (8) Universal Credits (per ECM) (credits sold separately).
- No other tuning or calibration tools can be used with the ECM.
- VCM Scanner, dealer diagnostic, and other diagnostic tools will continue to function normally.
- The latest version of VCM Suite can be used to return to stock calibration and/or update to the latest stock calibration.
- There is no need for an IMMO relearn, crank relearn, or the “Replace ECM” function as long as the ECM returns to the same vehicle it came from.
- Please allow 5-7 business days for this upgrade service, not including shipping times.
Step 1: Once you’ve confirmed your vehicle’s support, purchase this upgrade service. Make sure you have an MPVI3 or MPVI4 interface.
- If you’re new to HP Tuners, purchase a brand new MPVI4.
Step 2: After placing your order with the necessary information, see the “Shipping” tab for a shipping form and address. Fill out and print this form to place in your shipping box. You will also receive an email immediately after placing your order with this shipping form and address.
Step 3: Remove the ECM from your vehicle and safely package it. Then, package your ECM safely with the shipping form.
Step 5: Ship your ECM to HP Tuners using any carrier you prefer. The shipping address can be found on this page and in the email discussed in Step 2. Shipping costs are the responsibility of the customer.
Step 6: HP Tuners will upgrade your ECM for tuning and diagnostics. Then, we’ll ship it back to you.
Step 7: Once you receive your upgraded ECM, install it back into your vehicle. Then, license the upgraded E90 ECM by purchasing [8] Universal Credits (sold separately). Once licensed, start tuning with your MPVI3 interface and the latest version of VCM Suite BETA.
Send your stock GM E90 ECM to the following shipping address:
HP Tuners, LLC
ATT: GM E9o ECM Service (Global B)
700 Eastwood Ln
Please allow 5-7 business days (plus shipping times) per ECM/TCM for processing once your module arrives at our location for service. (i.e., 2 ECMs = 10-14 business days). This estimate does not include return shipping time.
NOTE: Any hardware ordered with this product will be shipped along with your upgraded ECM. To avoid any delays should you require other hardware soon, please order that hardware separately.
- These ECM/PCM/TCM services are completed at the owner’s risk. HP Tuners will not be responsible for the vehicle, its powertrain, or electronics, nor how the control module is used, calibrated, and its functionality.
- Due to the factory location of the ECM in the vehicle, all ECMs will exhibit signs of weathering and wear, which is completely normal.
- When utilizing this service there is a possibility that the vehicle will need to be sent to the dealers to be re synced. Purchaser accepts all liability for this activity.
Should you experience any issues with your ECM, please submit a ticket to our support team for assistance on how to proceed.
