PROLINK+ for MPVI2+, MPVI3, and MPVI4
$79.99
Get access to even more vehicle data using PROLINK+. Wire in up to 2x analog signals and 1x CAN bus signal with your HP Tuners interface. Compatible with MPVI2+, MPVI3, and MPVI4 devices.
Reminder: MPVI2+ requires the purchase of a Pro Feature Set to use PROLINK+. MPVI3 and MPVI4 come standard with Pro Feature Set, so only the PROLINK+ cable is required.
Overview
Designed for MPVI2+, MPVI3, and MPVI4, the PROLINK+ cable allows professional users to input 2x analog signals (from a wideband sensor, MAP sensor, boost pressure sensor, etc.) and 1x CAN bus signal simultaneously.
Reminder: If you have an MPVI2+ interface, you must purchase a Pro Feature Set to be able to use a PROLINK+ cable. The purchase of the Pro Feature Set for MPVI2+ includes a PROLINK+ cable free of charge (plus shipping).
Learn how to add PROLINK+ analog and CAN bus Inputs in the VCM Scanner help center.
PROLINK+ Specifications:
- 2x dedicated 0-5V analog inputs.
- 1x CAN bus input (500kbps).
- 100Hz sampling rate.
- M8 connector to 5 wire harness.
- Compatible with MPVI2+, MPVI3, and MPVI4 interfaces
Pro Feature Set enables the use of PROLINK+ and adds additional capabilities, including standalone data logging. Log directly to your interface’s internal storage without being tethered to a laptop — perfect for gathering data on the road, track, or dyno.
- MPVI2+ requires purchase of Pro Feature Set to use PROLINK+. One PROLINK+ cable is included with that purchase.
- MPVI3 and MPVI4 already include the Pro Feature Set, so you only need to purchase the PROLINK+ cable.
Learn more details about Pro Feature Set.
Pro Feature Set can be purchased on our website or from your MY ACCOUNT > MY DEVICES page.
