RENDER by HP Tuners
The brightest, fastest, and most rugged engine monitor and tune delivery device.
Coming in 2027. Sign up for an exclusive email list to be the first to know when RENDER becomes available!
BRING YOUR HP TUNERS TOOLS ALONG FOR THE DRIVE
RENDER connects with MPVI4 or RTD4 to put vehicle monitoring, data logging, diagnostics, and tuner-delivered calibrations within reach. Choose the readings you want to see, capture data for review, and stay connected to your tuner through the Tune Delivery Network.
BUILT FOR REAL AUTOMOTIVE ENVIRONMENTS
From daily driving and towing to off-road adventures and track sessions, RENDER gives you more ways to use your HP Tuners setup.
Features to Know
Monitor supported vehicle parameters and record data with VCM Scanner Lite. Dedicated onscreen recording controls help you capture useful information as it happens.
Work with your tuner through the Tune Delivery Network. Access tuner-delivered calibrations using your compatible HP Tuners interface.
Choose layouts for tuning, towing, off-road use, or viewing up to nine parameters at once. Customize the gauges around the data that matters to you.
Scan diagnostic trouble codes and access supported vehicle controls to help investigate issues and make adjustments.
Record location alongside vehicle data to connect an event in your log with where it happened. Use TrackAddict for lap timing and session review.
Set alerts for defined operating limits so changes in important readings can get your attention.
Water and dust protection helps RENDER handle demanding environments. Flexible mounting options include a magnetic mount and compatibility with select hard mounts.
Connection and Compatibility
Connect RENDER to an MPVI4 or fourth-generation RTD interface, or a newer supported interface, using the included HPTNET cable. The interface connects to your vehicle’s OBDII port.
MPVI/RTD interface sold separately. Vehicle parameters, tuning functions, and controls depend on application support.
RENDER can also run TrackAddict for lap timing without an MPVI/RTD interface. Vehicle data cannot be displayed or recorded in that configuration.
KNOW MORE ABOUT YOUR VEHICLE.
DO MORE WITH HP TUNERS.
Get the latest news on RENDER, the engine monitor and tune delivery device built to work with your HP Tuners tools.
