MPVI Battery Power Cable
$69.99
Power up your tuning. The MPVI Battery Power Cable ensures you can flash and log powersports vehicles that don’t have a built-in battery, like many motocross bikes. By connecting to any spare 12V battery, this cable provides the stable power your ECU needs during the flashing process.
SKU: H-001-03 Categories: ,
Overview
The MPVI Battery Power Cable is designed for powersports enthusiasts tuning vehicles without a factory battery. This cable connects to a standard 12V external battery to supply reliable power to the ECU for flashing and diagnostics.
  1. Provides required ECU power during flashing
  2. Alligator clips connect directly to any 12V battery
  3. OBDII connector plugs into your MPVI device
  4. Diagnostics port allows connection to your Powersports OBDII Adapter Cable (or other adapter, as required)
Compatible with models like:
  1. 2009-2018 Honda CRF450R
  2. 2010-2018 Honda CRF250R
  3. And any other supported model that does not have a built-in battery.
Installation
  1. Attach the alligator clips to the positive and negative terminals of your 12V battery.
  2. Connect the OBDII plug to your MPVI device.
  3. Plug the adapter cable into the diagnostics port.
  4. Power on and begin flashing with VCM Suite.
For detailed instructions, see the MPVI Battery Power Cable Installation Procedure
CA WARNING: This product can expose you to Nickel, which is known to the State of California to cause cancer. For more information, visit www.P65Warnings.ca.gov.
