Time Graph Parameters
When you select an individual signal (measurement) in the left column of Time Graph configuration window, the configurable properties for that signal appear to the right.
Parameter |
Description |
Label |
The name of this signal. This will be displayed in the legend on the left side of the Time Graph subwindow. |
Measurement |
Click this link to select the measurement whose output values will be charted. |
Unit |
Once the Measurement is selected, use this dropdown to select the units for the graphed measurement. For example, speed could be in mph or km/h. |
Decimals |
The number of decimal places displayed for this measurement on the Time Graph subwindow. |
Min Value |
The minimum signal value that will be displayed in the graph. This value will correspond to the bottom edge of the graph. Values below this will be cut off. |
Max Value |
The maximum signal value that will be displayed in the graph. This value will correspond to the top edge of the graph. Values above this will be cut off. |
Color |
The signal's color in the Time Graph subwindow. |
