Adding a Measurement List
A measurement list is simply a list of measurements, displayed as a two-column table, with the signal name in the left column and the current output value of the signal in the right column.
To add a measurement list,
1. In the menu bar, select Layout Add Control > Add MeasurementAdd Measurement List. A window showing the properties for the new measurement list appears.
2. Add measurements to the list (see below for instructions).
3. When configuration is complete, Click Create Window.
Adding a Measurement to the List
1. Click .
NOTE: Step 1 is not necessary for the first measurement added. One unconfigured measurement is already present in a new list.
2. In the left column, select the new measurement. Parameters for the new measurement appear on the right.
3. In the right column, click the Measurement box. A list of available measurements appears.
4. Double-click on the measurement whose output you want to display.
5. Complete signal setup by configuring the signal's parameters.
Editing an Existing Measurement
1. Select the name of the signal in the column on the left.
2. Modify the signal parameters displayed on the right.
Toolbar
Add a new measurement to the list. To complete signal setup, you must configure the signal's parameters.
Delete the measurement selected in the left column.
Duplicate the signal measurement selected in the column on the left.
Move the signal selected in the left column upwards in the list.
Move the signal selected in the left column downwards in the list.
