Adding a Gauge Group
A gauge group is subwindow that can contain multiple gauges. This allows the group to be moved and resized as a unit.
In the menu bar, select Layout > Add Control > Add Measurement > Add Gauge Group. An empty gauge group appears. |
Add the individual gauges: |
a.
Right click inside the empty group. A popup menu that lists gauge types appears. |
b.
Select the type of gauge to add: Dial Gauge, Bar Gauge or Numeric Gauge. A window showing the properties for the new gauge appears. |
c.
Configure the parameters for the new gauge. These is identical to configuring the same gauge types as standalone gauges. |
