Editing Tunable Parameters
In order to modify a parameter supported by the ECU, the parameter must be included in at least one subwindow of your layout. There are two subwindow types which allow editing of tunable parameters:
Characteristic Lists are lists of tunable parameters, with the parameter name on the left and the corresponding value on the right. Some parameters in these lists allow you to enter a numerical value. Others, require you to select a specific value from a dropdown. See Tuning Listed Characteristics |
Table Editors are used to modify tunable tables. See Editing Tables for more information. |
Additionally, the following features can be used to modify parameter settings:
The Upgrade Tune feature allows you to import desired parameter values from a saved tune file. See Upgrading and Comparing Tunes for more information. |
NOTE: See the Core Parameter Guide for descriptions of individual parameters: https://files.hptuners.com/help/CoreParameterGuide.pdf
