Measurement Parameters
When you select an individual measurement in the left column of the Measurement List configuration window, the configurable properties for that signal appear to the right.
Parameter
Description
Label
The name of this measurement. This will be displayed in the left column of the Measurement List.
Measurement
Click this link to select the measurement whose output values will be displayed.
Unit
Once the Measurement is selected, use this dropdown to select the units for this parameter. For example, Speed could be in mph or km/h.
Decimals
The number of decimal places displayed for this parameter in the Measurement List.
Add New Range
Click this button to define a range of values for this measurement that will cause the value to be displayed in a different color. For example, you may wish the value to displayed in red if it's above the safe operating limits for the engine.
