Adding a Characteristic List
Characteristic lists contain a number of tunable parameters whose values can be adjusted by the user. To add such a list,
1. In the menu bar, select Layout Add Control > Add Characteristic > Add List. A configuration window for the new characteristic list appears.
2. In the left column, select the unconfigured characteristic.
3. In the right column, click the Characteristic box. A list of tunable parameters supported by the ECU appears.
4. Double-click on the characteristic you wish to add.
5. In the right column. configure the parameters displayed.
6. To add additional characteristics to the list,
a. Click .
b. Repeat steps 2 through 5 for the new table.
7. When all the characteristics that you want to include in the list have been added and configured, click Create Window.
Toolbar
Add a new characteristic to the list. To complete setup, you must configure the characteristic's parameters.
Delete the characteristic selected in the left column.
Duplicate the characteristic selected in the column on the left.
Move the characteristic selected in the left column upwards in the list.
Move the characteristic selected in the left column downwards in the list.
