The Table Editor Toolbar
The toolbar in Table Editor has many options for viewing and modifying tables.
Select View
Selects the table view. In split view mode, the table is always one of the views in the split. |
Selects the 3D graph view. In split view mode, this changes between 2D, 3D and histogram view. |
Selects the 2D graph view. In split view mode, this changes between 2D, 3D and histogram view. |
Selects the histogram view. In split view mode, this changes between 2D, 3D and histogram view. |
Single View Vs. Split view
View only one data representation (table, 2D/3D graph or histogram) |
Use a vertical split with the table display on the left and the graph or histogram on the right |
Use a horizontal split with the table display on top and the graph or histogram on the bottom |
Precision
Increase decimal precision (add a decimal place) |
Decrease decimal precision (remove a decimal place) |
Modify
Replace selected cells with the value in the box |
Add the value in the box to the selected cells |
Multiply the selected cells by the value in the box |
Smoothing and Interpolation
Smooth the entire selection |
Smooth the selection only using a horizontal pass |
Smooth the selection only using a vertical pass When using the smoothing functions, the level of smoothing will be determined by your current precision. To increase the effected area of your smoothing, increase your precision |
Interpolate the entire selection (flat plane) |
Interpolate between horizontal bounds (creates lines) |
Interpolate between vertical bounds (creates lines) |
