Measurement list subwindows contain simple lists of ECU measurements with two columns: Name and Value.
When actively recording a connected ECU or playing back a log file, VCM Live updates the Value column in real time to reflect the live or recorded measurements.
Changing the Display Properties for a Parameter
To modify the display properties for an individual parameter, right click on the parameter you wish to modify. A menu of configurable parameters appears:
| ■ | Polling Interval. Change the polling interval for the measurement. |
| ■ | Units. Change the displayed units for the measurement. |
| ■ | Decimals. Increase or decrease the number of decimal places displayed for the measurement. |
Modifying the Subwindow
To make changes to the entire subwindow, such as adding or removing measurements, renaming the subwindow, or resizing it, see Subwindows
