Connecting to a Vehicle
When used with VCM Suite
When used with VCM Suite, a USB connection to your PC is recommended:
1. Connect the provided USB-C cable to the MPVI device and the opposite end to your laptop with VCM Suite Installed.
2. When you are ready to scan or reprogram the vehicle, plug the large, molded OBD-II connector on the other side of the interface device into the vehicle's diagnostic port.
NOTE: See the VCM SUITE GETTING STARTED GUIDE.
where is my obd diagnostic port?
On most vehicles, the OBD diagnostics port can be found on the underside of the dashboard (instrument panel) on the driver side of the vehicle. But, the location varies from vehicle to vehicle. Consult your vehicle's owner's manual for the exact location of its OBD diagnostics port.
WARNING: A 20A maximum size fuse is required ahead of the unit. Consult your vehicle owner's manual for the location and rating of the OBD port fuse.
When Used With the TDN App
When used with the TDN app for mobile devices, the MPVI4 connects to your mobile via Bluetooth®. The app provides on-screen instructions for establishing the connection and attaching the device to your vehicle.
NOTE: See the TDN APP USER GUIDE.
