MPVI4 Face Plate Description
Below outlines the legacy features on the face plate of the MPVI4, with a detailed description of each LED RGB (red, green, and blue) and bluetooth status icon.
1. MPVI4 Face Plate
2. HPTNET Screw on Connector
3. Status LED Icon
4. Bluetooth Low Energy (BLE) LED
5. WiFi LED
6. Standalone Data Log & Bluetooth Button
7. USB-C
CAUTION: When over-voltage is detected , the MPVI4 Status LED will become solid red and will remain solid red until voltage drops below 15.5v, then it will go back to solid green. Operating the MPVI4 with voltage over 15.5v can cause damage to the MPVI4.
NOTE: When an overcurrent event is detected, the firmware attempts recovery by cycling the bus OFF and ON up to three times, checking if the current drops below the threshold. If any attempt succeeds, normal operation resumes. However, if all three attempts fail and the current remains high, the LED turns solid red. At that point, only a power cycle or OBD reset will allow the MPVI4 to recover.
MPVI4 RGB Status LED Description Table
Color
Description
No Color
Off/No App Running
Solid Blue
MPVI4 is powering on
Medium Blue
MPVI4 Safe Mode Initiating
Blinking Blue
MPVI4 Safe Mode Running
Fast Blinking Blue
MPVI4 Safe Mode USB Active
White
MPVI4 Safe Mode Ended Successfully
Solid Red
MPVI4 Safe Mode Exit Failed
Blinking Medium Blue & Medium Yellow
MPVI4 Safe Mode Firmware Update
Medium Yellow
MPVI4 Safe Mode Firmware Update Successful
Blinking Medium Blue & Medium Red
MPVI4 Safe Mode Firmware Update Failed
Medium Blue
MPVI4 Main Application Starting
Medium Green
MPVI4 Main Application Running
Fast Blinking Green
MPVI4 USB Main Application Activity
White
MPVI4 Main Application Exit Successful
Solid Red
MPVI4 Main Application Exit Failed
Fast Blinking Medium Green
Main Application USB Communication
Fast Blinking Medium Green & Medium Magenta
Main Application USB+OBD Communication
Fast Blinking Medium Yellow
Main Application Task Starting
Blinking Yellow
Main Application Task Running
Flashes Red, Yellow and Red, Yellow again then will remain Green
Main Application Task Returned False
Main Application Task Exception
Blinking Medium Green & Medium Yellow
Main Application Firmware Update
Medium Yellow
Main Application firmware Update Successful
Blinking Medium Green & Medium Red
Main Application Firmware Update Failed
MPVI4 RGB bt (bluetooth) LED description table
Color
Description
Blinking Blue
When blinking slowly the MPVI4 is in pairing mode. When blinking quickly the MPVI4 is paired with the users bluetooth device.
White
Bluetooth has unpaired successfully
Solid Red
Bluetooth Failure Detected
Cyan Blue
MPVI4 Bluetooth Device Connected
MPVI4 standalone data logging & Bluetooth button
This button (refer to below image) can be used to connect your bluetooth device to your MPVI4. This button can also be used to start and stop your standalone data logging. Below outlines the RGB LED light and their corresponding description associated with the standalone feature.
Color
Description
Blinking Blue
When the STAT light is blinking fast blue the standalone action has started. When it is blinking blue slowly the standalone action is in progress
Blinking Purple
MPVI4 Standalone Failed to Start
