Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 69
Thread: A580 Tuning is Here! EGS52/EGS53
    This is great news!!
    That is pretty slick, I cant wait to play with the tcm on a couple cars.
    Gen3 Hemi Tuning
    FAST, Holley, AEM, DiabloSport, Mopar Performance
    Resto-mod EFI Conversions and Support
    Feb 2015
    25
    TCM Template Ppoulatiom
    Quote Originally Posted by HemitunerAJ View Post
    Since 4 or more platforms use the same calibration ID ECU how are you populating which shift tables are in use?
    AJ
    This question seems to keep getting a pass so Ill ask again. Being the same calibration ID is used across different engine families how is the software populating for that family, or is it?
    AJ
    How deep are you guys going into the BCM? If you could map out the DTC's for the TCM/BCM that would be awesome. You would solve the problem of putting a gen3 with a 580 into restomod stuff. The front wheel speed correlation stuff needs to be shut off to make it all work.
    Gen3 Hemi Tuning
    HPT Employee Engineer@HPT's Avatar
    fecadefa
    615
    Quote Originally Posted by TurboTBSS View Post
    TCM DTCs are already mapped and working as of this morning's version. No plans to map BCM DTCs at this time, sorry.
  6. #26
    fecadefa
    615
    AJ
    If you are tuning the original TCM from the vehicle or if it's a replacement TCM and it has been in the vehicle already, the tables will be populated properly.
  7. #27
    Quote Originally Posted by Engineer@HPT View Post
    Roger that, I would look at it if I were you guys. The gen3 swap is really gaining momentum and the main trans that came with them is the 580. The cars are 10 years old now and there are lots and lots of these in junkyards waiting to be swapped. Right now there is NO reliable solution for using the 580 in anything other than a stock car.
    Gen3 Hemi Tuning
  8. #28
    fecadefa
    615
    What are the BCM codes that are being set?
  9. #29
    Feb 2015
    25
    You can use a TIPM Module from any 2005-2007 Charger,or 300 and an ABS module (just the brain). Works great we use this all the time in resto-mod builds here.
    Hope this helps
    AJ
  10. #30
    Nov 2014
    Read tcm
    Cant read pcm only tcm
  11. #31
    fecadefa
    615
    Redownload the software tomorrow morning. Should read fine.
  12. #32
    Nov 2007
    MI
    686
    does anyone have a stock file that has the trans tables they would be willing to share? The ones in the repository do not have any trans tables.
    2018 Camaro SS, Maggie 2650, 103 TB, Big Gulp, E85
  13. #33
  14. #34
    Nov 2007
    MI
    686
    hmm strange im not seeing any trans tables. I have version 2.25.2484 too
  15. #35
    May 2015
    1,908
    That file was read wrong, didn't include a read of the TCM in the stock file.
  16. #36
    Sep 2011
    Portland, OR
    523
    We have read 3 cars with the latest release. Two 2012 and one 2013.
    The 2012 did have tweaked TCM modules.
    The 2103 Jeep SRT TCM is stock to our knowledge.
    In each case the message about outdated TCM calibration comes up.
    What gives?
  17. #37
    Sep 2008
    Portersville, Pa
    289
    Quote Originally Posted by RonSSnova View Post
    What gives?
    I have encountered the same issue with several TCM's I have read. It appears that a new version of the TCM software is automatically loaded. I believe this note on the first page of this thread indicates this is what will occur:
    "Please note that we will not support some outdated EGS53 operating systems (we will update your TCM OS automatically to a newer/supported OS)."
  18. #38
    HPT Employee Mark@HPTuners's Avatar
    Jun 2014
    36.1094, 115.1781
    432
    What gives?
    Like Mike pointed out, if you have an unsupported/outdated OS, we will have to update you to a newer/supported OS. If VCM Suite doesn't do this and you still can't access the TCMs, please email support with your .HPT file and VCM Suite Infolog.
  19. #39
    Potential Tuner almadhen's Avatar
    Dec 2007
    3
    Great Job Bill, HP TUNERS forever
  20. #40
    Neosho Missouri
    14
    Newbie question. I just downloaded the new version of Beta sofware to attempt TCM tuning but it will not let me re-read the vehicle. The vehicle is a 2012 Charger SRT-8. What am I doing wrong?
