Results 1 to 13 of 13
Thread: Stock LS3 2010 camaro DTCs
    Yesterday from just driving from work to home the SES light popped...
    scanned it and I'm getting these:
    [ECM] P0030 - HO2S Heater Control Circuit Bank 1 Sensor 1 (SES) (Pending) (Old) (History) (Current) (Immature)
    [ECM] P0053 - HO2S Heater Resistance Bank 1 Sensor 1 (SES) (Pending) (Old) (History) (Current) (Immature)
    [ECM] P0135 - HO2S Heater Performance Bank 1 Sensor 1 (SES) (Pending) (Old) (History) (Current) (Immature)
    O2 sensor fail?
    Quote Originally Posted by Luis Castellanos View Post
    O2 sensor fail?
    If you have longtube headers. Turn the codes to no error reported.
    G-FORCE Motorsports
    1941 CR 129 Pearland TX 77581
    281-993-5451 PH 281-993-5421 FAX
    www.gforce-tx.com
    [email protected]
    PCM Tuner LSX and SCT <-> How Much Force Can You Take??
    2009 CTS-V 630 RWHP 10.90 @ 129mph
    Quote Originally Posted by Mike@G-Force View Post
    completely stock car
    just scanned it in a short drive.. the B1 sensor is dead at 400ms for a good while... after some driving i guess it finally heats up and starts working..
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,863
    No. That's a front sensor... I'd want to know if my front sensor had a legitimate problem (aside from insufficient switching).
    To the OP, check to make sure the plug connection is solid. Disconnect the plug, and then reconnect it. Scan again. If the problem comes back, then swap the front sensors (driver side to passenger side, and vice versa). See if the error follows the sensor. If you start getting errors for Bank 2 Sensor 1, then you know the sensor itself is screwed up.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Ok will do that
    Thank you
    Tuner coryfountain's Avatar
    Jul 2009
    Lafayette, La
    69
    If it is a completely stock car, is bringing it in for warranty out of the picture??
    never trust a delear something you can do in 2 minutes, if the sensor is failing then I do know whats the problem, take it to service and when they tell me that I need a new crankshaft because I didnt oil the tires I will just ask for a new O2 sensor
    yeah definitely sounds like an 02 sensor gone bad. All those errors are coming from the same sensor, all the others don't seem to be showing problems
    I just quickly read the post. Didnt see it was only one bank. But LS3 cars will throw the heater DTC's on the front sensors when Longtube Headers are installed. Period. If you havent seen it yet you will.
    G-FORCE Motorsports
    www.gforce-tx.com
    [email protected]
    ohhmm.. that's something my brother's car was doing... weird, we thought the collectors were too far away (custom headers).. thanks for the usefull info!
    Mar 2008
    St. Louis, MO
    4,863
    5000+ miles on one with only P1133/P1153 showing up. Same with every other 2010 I've done. I find it hard to believe that it wouldn't pop up at least once in the last year, aside from when a connector wasn't fully seated.
    Ive tuned 40 plus 2010 Camaros and countless Ls3 Vettes. The code will appear.
    G-FORCE Motorsports
    www.gforce-tx.com
    [email protected]
    Jul 2009
    Lafayette, La
    69
    I never said "trust the dealer" . my point is, its their warranty(you paid for it), and they should pay, let them replace it.. And yes its always good to know what you are talking about to those guys at the dealer ship... Some i have met don't deserve to be called technicians.
