What is Pro Feature Set?
The Pro Feature Set is an enhancement to MPVI2 and MPVI2+ that takes the capabilities of these interfaces to the next level. Pro Feature Set is standard on MPVI3.
At present, purchasing the Pro Feature Set adds the following features:
■ | Support for Pro Link and Pro Link+ |
■ | Standalone Data Logging |
Additional features are planned.
The Pro Link and Pro Link+ are cables that allow additional inputs to be connected to the MPVI2, 2+ and 3 for enhanced data logging. This allows you to see these additional signals in VCM Scanner, potentially providing critical insights into how your tune is performing.
■ | Pro Link allows you to connect up to two analog signals (such as a wideband sensor or a map senor) and one CAN bus signal to an MPVI2. |
■ | Pro Link+ allows you to connect the same inputs to an MPVI2+ or MPVI3. |
When you purchase the Pro Feature Set for your MPVI2/2+, we will send you the version of the Pro Link cable that supports your interface.
Although Pro Feature Set comes standard on the MPVI3. The Pro Link+ cable must be purchased separately for this interface. To order, go to https://www.hptuners.com/product/pro-link-plus/.
Standalone Data Logging lets you log directly to the internal storage on your MPVI2+ without being tethered to a laptop. It is now easier than ever to collect data while driving. Easily record your vehicle’s data on the go with a press of a button or pre-set start/stop triggers. Then, at your convenience, evaluate and customize start/stop conditions right on your PC or laptop.
