The Table Editor Toolbar
The toolbar in Table Editor has many options for viewing and modifying tables.
Table Open, Save and Print
Import a table from a file and overwrite current table.
Save the table to a file.
Print the table.
Favorites
Add this table to your favorites.
Remove this table from your favorites.
See Using Favorites for more information.
File Compare
View the table for the primary calibration
View the table for the compare calibration
View the differences between the primary and compare calibrations
NOTE: These icons change the view for the current table only. To change the view for all open tables, use the icons in VCM Editor's main toolbar or in the Compare menu. See Comparing Two Tune Files for more information.
Reload
Reload the current table
Copy and Paste
Copy table selection to clipboard
Paste table selection from clipboard
Modify
Replace selected cells with the value in the box
Add the value in the box to the selected cells
Multiply the selected cells by the value in the box
Single View Vs. Split view
View only one data representation (table or 2D/3D graph)
Use a horizontal split with the table display on top and the graph on the bottom
Use a vertical split with the table display on the left and the graph on the right
Select View
Selects the table view. In split view mode, the table is always one of the views in the split.
Selects the 3D graph view. In split view mode, this changes between 2D and 3D graph view.
Selects the 2D graph view. In split view mode, this changes between 2D and 3D graph view.
Precision
NOTE: The functions of these two icons were swapped in VCM Suite version 4.12. (If you are using an older release, use the description for the other icon in this list).
Increase decimal precision (add a decimal place)
Decrease decimal precision (remove a decimal place)
Smoothing and Interpolation
Smooth the entire selection
Smooth the selection only using a horizontal pass
Smooth the selection only using a vertical pass
When using the smoothing functions, the level of smoothing will be determined by your current precision. To increase the effected area of your smoothing, increase your precision
Interpolate the entire selection (flat plane)
Interpolate between horizontal bounds (creates lines)
Interpolate between vertical bounds (creates lines)
