Parameter Options
Right-clicking on the colored background of any parameter displayed in the Tab Navigation System or in the right pane of the Parameter Navigator will display a menu containing options for the parameter.
The options displayed are different for each type of parameter. They may include the following:
Copy. Copy the value of this field to the clipboard. This allows the same value to be pasted into another field later. |
Paste. If you have copied the value of another field to the clipboard, select this option to paste it into the current field. |
Undo Changes. Select this option to revert the field back to the value in the last saved version of the tune file. |
Units. Select this option to change the displayed units for this field. |
Decimals. Select this option to add or remove decimal places from the value displayed in this field (increase or decrease the precision of the displayed value). |
Favorites. Select this option to add this field your favorites (or remove it from your favorites). |
