Parameter Navigator
The Parameter Navigator window (sometimes called "tree view") can be useful if you need to quickly search through all available parameters to find a specific parameter you need to change.
To open Parameter Navigator, select Edit > Navigator in the menu bar.
Selecting and Editing Parameters
Available parameters are listed in the tree on the left. Click on a listed parameter or parameter group to display that parameter or group in the pane on the right.
NOTE: In the image above, we clicked on Engine > General > Engine. Both parameters in the group appeared on the right.
The user interface for the fields displayed on the right is no different than when the fields are displayed in tab view. You can interact with them the same way here:
■ | Hover over a parameter to see a brief description for the parameter at the bottom of the window. |
■ | Edit parameters as needed. See Modifying Parameters. |
■ | Right-click on the colored background of any parameter name to see a menu containing options for the parameter. See Parameter Options. |
Filtering the Tree Display
When you need to quickly find a specific parameter or group of parameters, there are a number of ways to filter the fields listed in the tree.
Filtering By Parameter Name
To filter the tree display by parameter name, enter the text you wish to search for in the [Text Filter] box above the tree. The displayed tree items will be dynamically filtered as you type.
Filtering by Data Type
The group of icons on the left end of this window's toolbar are used to filter displayed items by data type.
When a blue box appears around the icon, items of this type will be displayed. When the blue box does NOT appear, items of this type will NOT be displayed. Click the icon to turn the display off. Click again to turn it on.
Switches |
Scalars |
Tables |
DTC Lists |
Code Mods |
Filtering by Parameter Group
The middle group of icons in the window's toolbar are used to filter displayed parameters by group.
When a blue box appears around the icon, the corresponding parameter group will be displayed. When the blue box does NOT appear, the group will NOT be displayed. Click the icon to turn the display off. Click again to turn it on.
Operating System |
Engine |
Engine Diagnostics |
Transmission |
Transmission Diagnostics |
System |
Fuel System |
Speedometer |
Filter By Basic / Advanced
The final two icons in the window's toolbar filter by whether each parameter is considered to be "basic" (for beginners) or "advanced" (for more experienced tuners).
Basic Parameters |
Advanced Parameters |
