Results 1 to 20 of 29
Thread: barometric learning 2007 dodge ngc-4
    Jun 2023
    11
    Smile barometric learning 2007 dodge ngc-4
    could someone please explain to me exactly what barometric learning does on my 2007 dodge ram 5.7 hemi with a NGC-4 PCM. Thanks
    It updates the Barometric pressure reading, which is critical to its fuel calcs.
    Its purpose is to keep the engine running a bit better just in case you drive straight off the beach to the top of a 5000ft mountain without ever shutting off the engine.
    When you add Boost, it MUST be disabled.
    Aug 2017
    Quakertown PA
    483
    Quote Originally Posted by duster360 View Post
    you realize the difference in Baro between Philly(39ft elv ) Denver(5280elv) is .005 Bars on an average day.
    today(5.12.24)in Denver@ 8am it's 30.27(1039Millibars, 14.87psi ) and 29.87(1011Millibars, 14.67psi) in Philly, At Mount Davis in PA (3213elv) it's 29.67(1005millibars ,14.57psi.....so
    No it's not what barometric learning does.
    to answer the question, (Dave is partially correct, it is used in fuel calc)
    1st understand that IAT,MAP, o2 sensors take other readings also,
    the ECU takes LOCAL Barometric reading (actually in Millibars) and compares it to an average MAP(in Millibars) value taken from W.O.T events and uses it as a "standard" ....the ECU doesn't care where you are or what the outside baro value is , just what the difference is between outside Baro(measured at the IAT sensor) and Manifold Air Pressure ,
    In operation at or above Throttle Delta(Table 44267)the ECU uses actual current MAP reading in fuel calculations, below Throttle Delta it uses the stored "standard" Value, reason being is fluctuations, reversion and inconsistent air density are more prevalent have a greater +/- swing during part throttle acceleration(check the attachments)
    In theory Map + Manifold vacuum should equal Atmosphere pressure(Baro) , but reality is we have a few things that keep that from happing.....look at the Attachment L1 it's a 30sec screen grab, in the White circle this 04 ram stock expect K&N cold air intake. is at Idle & a little dry hop to clean the tires, the Yellow Line is a math parameter, Manifold Vacuum mins the combined value of Baro-MAP, at Idle the Yellow line is very erratic ups & downs, now the Next attachment is same log capture of a 0ish to 60ish romp, the yellow line is not perfect but has less dips and No bumps in-till gear shift. ,last attachment is the same truck (same log) pulling away from a traffic light, there is a yellow reference added(line = 0)...Notice it's ALL over the place....
    Point is , instead of constantly needing to readjust base point for fuel calculations it uses pre stored average.
    Now some real world results, in the last 10 years I've bought, sold, and worked on over 100 3rd gen rams, I currently own 20 , three are track only trailer queens, one is a low 11 daily(ish)driver another one is amid 12 ish daily and the another 8 used somewhat on a weekly basis(yes Insurance is a F'N b!tch)
    Every truck(or Hemi car) I've had, I get base line Logs roughly 40 hours worth, every time I compare Fuel Millage between Baro Leaning enabled and disabled , Enable is Always 2 MPG average better.
    G3 Hemi Videos
    826
    Apr 2024
    Telford PA
    13
    And that has nothing to do with the question, or any of the answers.
    Gonzo= 14 Ram 4x2 441Ci 9:90s on pump 93
    Lazy boy= 12 Ram 4x2 362Ci 11:80s on pump 93
    The Bee= 04 Rumble Bee 4x2 370ci 10:60s on pump 93
    826
    Quote Originally Posted by 3dodgechick View Post
    Maybe this will help.
    https://forecast.weather.gov/product...t=OSO&site=bou
    Seems like a drag racer would understand the effects of DA, but maybe not?
    Quote Originally Posted by PurpleRam View Post
    ..... (Dave is 1000% correct)
    LOL...i love it when the ignorant are so arrogant when shouting their ignorance for all to hear.
    You realize the difference in Barometer readings used for weathermen are not actual Absolute Pressure read by a MAP sensor? Obviously not..... lol
    Here read this: https://www.weather.gov/bou/pressure_definitions
    Meteorologist use "MEAN SEA LEVEL PRESSURE" . Your stated Barometer values are normalized for local Altitude so the simple minded(??) don't get too confused.
    All experienced tuners know that a 5300ft altitude is typically around 85kPa or about 12psi.
    I've tuned cars in Mexico City, Mexico where Baro is in the mid to high 70s ~10psi
    So when your Baro goes from reading 101kpa in San Diego and then go skiing at Snow Summit(7200ft) the BARO as measured by your car's MAP sensor would be off BY over 2psi, if Baro learning wasn't working.
    That would mean WOT Pressure Ratio would be go from 1.0 on the Beach to .8 on the Mountain without Baro Learning. For that heap of shit 20 year old Ram in question, that would mean the VE is off 2 Rows and NONE of Baro Corrections are doing their job.
    All factory Boost cars, Hellcats, Srt-4, take and actual Baro reading. NA cars, use "WOT" to readjust Baro.
    Yes is certainly does. @spoolboy just correcting the misinformed.
    Apr 2024
    Telford PA
    13
    Well Speaking of ignorant, No need to insult the original poster's ram for asking what Baro learning does on his ram with an NGC4 ECU, Not a Hellcat , Not an SRT 4 , Not sensed map, Not VE modifiers, I understand what DA is, and if you two ignorant phucks think any of this has to do with what Baro leaning does on one of these , no wonder I've fixed a few of Dave Trojan and Dennis Dosa (I know I didn't get that right, I do sincerely apologize for the misspelling ) tunes over the last few years.
    you both can keep on being "also rans"
    LoL , and I use to wonder why people laugh at you Dave.
    826
    Aug 2010
    Detroit, MI
    973
    Lot of angst in here. Nobody's got it quite right though... Who wants to hear about this feature from a former Chrysler engineer who has actually been balls deep with these algorithms?
    Jan 2022
    959
    Quote Originally Posted by smokeshow View Post
    Not me. Not me
    I do not
    Check out old Addy
    https://youtu.be/9tJri3uuVf0?si=OjnvzZIm0olp88bf
    She knows about station pressure and how low the avg in Denver is : )
    826
    Not me either. I've worked with enough engineers to know they're usually full of shit or incapable of grasping reality outside of a computer model. If you were going to inform us, you would have.
    If there's one thing engineers love, it's telling everybody how smart they are.
    Aug 2010
    Detroit, MI
    973
    Damn, figured you'd give me a little more credit than that lol. Might as well have fun with it while I'm at it right..
    No one knows you or cares....but that's not a shock as you're just another rando with an inferiority complex just spouting off in hopes for a shred of recognition but as typical of your kind, offering nothing, contributing nothing and never having anything worthwhile to share.
    I've seen carnage after my tunes get "fixed" by some no-name, tard. Sure thing rando...lol
    Go for it.
    Besides what I already said, I'd should have added Throttle Airflow since its DBW
    826
    Go for it.
    He won't. He's full of shit.
    Aug 2017
    Quakertown PA
    483
    You two risible clowns if your reading comprehension was as good as you think your tuning capabilities are , you'd understand why you're both wrong.
    So if either one of you all mighty tuners have the balls , you'll take a NA Hemi car(truck, hell a G3 swapped Yugo with Gpec2 PCM) Take it for log ride with Baro Learning enabled, all you need to record is Baro and Throttle(in Volts) , Key on Engine off, take note of the Actual Baro reading(in Bars) compare to the Logged Baro reading , start the car, drive around and make at least on W.O.T hit.(that's Wide open Throttle hit , just want to make sure you can UNDERSTAND the directions) now it doesn't have to be a full 1/4 mile blast, wouldn't want either one of you to go faster than your comfortable with take note to what happened to the recorded Baro values ...make sure you save the log ....Now repeat with Baro Learning disabled...Make sure you get that W.O.T hit in there...... and compare the recorded Baro Values.......Now after all is said and done if either one of you two MOE-RONS are willing to admit the results , you'll donate $1k to St Judes .......So while my niece(3dodgechick) and her hubby Benny(one of the guys who wrote the base code for DCX/FCA) are working at Autodromo Enzo e Dino Ferrari this week TUNING an F1 car. , and I'm here in Austin working on TUNING a GT3 car.....you two clowns are most likely sitting in your underwear watching Facebook videos
    G3 Hemi Videos
    826
    Benny might be pretty smart, but unfortunately for you it doesn't seem to be contagious.
    I was crewing for Dodge SCCA cars 25 years ago. Showroom stock Neons and a GT3 Daytona. So what? That doesn't mean you know what you're doing, just that you're willing to spend a weekend at the track and know someone that races.
    My point was this statement is incorrect:
    "you realize the difference in Baro between Philly(39ft elv ) Denver(5280elv) is .005 Bars on an average day.
    today(5.12.24)in Denver@ 8am it's 30.27(1039Millibars, 14.87psi ) and 29.87(1011Millibars, 14.67psi) in Philly, At Mount Davis in PA (3213elv) it's 29.67(1005millibars ,14.57psi.....so"
    And it is still incorrect.
    Baro 86Kpa somewhere in Idaho
