Results 1 to 20 of 26
Thread: injector change running rich
    Dec 2021
    15
    p59 with 12613412 injector i change data i found on here.. but its running rich everywhere i did some correction is it normal to do tunning all over again if data are right or i dont have good injector data ?
    Advanced Tuner dhoagland's Avatar
    Jun 2015
    Aubrey TX
    890
    Post your tune and a log and you will get more responce
    7,901
    If you bought 12613412s from the cheapest random ebay listing you could find, you probably have fakes.
    https://www.youtube.com/watch?v=2h8n2hQWlaA
    Dec 2021
    15
    they are used oem injector but not flow tested
    7,901
    For one thing, you're not in closed loop because you have O2 heater DTCs. And that injector flow rate is only correct if you're running a referenced regulator at something other than 58psi, and have done the conversion so that it matches your actual fuel pressure. You described precisely nothing about the rest of your fuel system.
    7,901
    The fuck is this?
    The MAF also looks like a drunk guy beat on it with a hammer.
    /shakes head, walks away
    Feb 2017
    miami
    1,799
    Its mount kilomapbaro!!
    Jun 2015
    Aubrey TX
    890
    My injector swap only needed minimal adjustments.
    But prior to my upgrade my air flow tables were pretty dialed and I had very accurate data to input (went from stockers to flex to accommodate running E85)...
    I'm assuming you are using the A/C input for a wideband to create an error log for corrections?
    If so had you used this in the past? Are you 100% sure its setup correctly? (as mentioned, the VE table posted says there is something wrong with the process).
    Why did you swap injectors in the first place, upgrade or did you have performance issues?
    You say they are used, did you know the donor car to be a good running car?
    Do you have the Tune prior to the swap and adjustments?
    As blindsquirrel said, you need to tell us more about your fuel system for anyone to be able to help with the conversation for your data:
    Return or Returnless
    Vacuum referenced regulator
    Rail Pressure
    ETC...
    Dec 2021
    15
    yeah using a/c for my wb its seam right.. what seam wrong in the process ? its my first time to tune.. it was not done tuning before the injector swap.. i change them cause i was hiting like 105 duty on stock truck injector.. and was still lean so that why i change for those 12613412
    fuel system is return style with stock regulator vacuum referenced .. 52 psi at the fuel rail mesure with a gauge
    here my latest file before swap injector
    the tune is probably bad but im trying to learn haha
    canyon basemap 2022 5.3 cam tune2.hpt
    Jun 2015
    Aubrey TX
    890
    Quote Originally Posted by T0mmy_boy1 View Post
    Is this the original file, meaning it was running good with this VE Table?
    (as blindsquirrel pointed out, this aint good, almost cant be stock)
    I'm thinking you need a fresh start.
    Do you have an original read from your ECM?
    I'm looking at your injector flow
    Dec 2021
    15
    yes i have a original before i change anything
    it was running ok before i change injector not perfect but drive ok and was at 14.7 most of the time when looking at wideband
    Dec 2021
    15
    before i start again i want to be sure my injector data is right
    and i was only tunning maf with new injector i dont have done anything to the ve table
    Jun 2015
    Aubrey TX
    890
    Understood, but if the VE is that far off I believe it can make a difference on things like start up, throttle transitions.
    If it was me I would find a stock table and put in there even for MAF only tuning.
    I'm no expert, but I believe your injector data is okay.
    Please double check me.
    This conversation sheet has L96 data converted to your file. Since you are vacuum referenced and running 50 PSI you use the 348kpa column straight across, which appears to be what you did.
    This sheet shows some different values for the offset vs voltage?
    But since you are vacuum referenced I believe you use the "0" column all the way across, as you have.
    Jun 2015
    Aubrey TX
    890
    Where did the Injector data come from?
    Dec 2021
    15
    ls1 tech here and ewalt auto tuning i compare some data but they were all different a little bit
    for the offset table i take data at 0 kpa and paste everywhere ( since im vaccuum referenced ) is that right ? picture original post
    and default injector pulsewidth should be same across the rpm ? the data i found was 0 after 3600 rpm
    Jun 2015
    Aubrey TX
    890
    I believe you are good
    But as I said I'm not expert here, and really would hate to be the guy giving bad advice.
    Jun 2015
    Aubrey TX
    890
    You mentioned you were only Tuning MAF
    This Tune posted is not set to MAF only
    Dec 2021
    15
    your right here what i used for maf
    canyon basemap 2022 5.3 cam tune2 injector 12613412 maf 3.4.hpt
    it is really juste injector data that i want to be sure is good to continu to learn how to dial my maf table after running good in maf ill do ve table
    and thanks everyone that help me here!
    7,901
    52psi at the rail, with the vacuum line disconnected and plugged? What's pressure with the vacuum line connected? Did you verify that pressure is steady on throttle snaps and WOT pulls, with the vacuum line disconnected?
    Use all of the converted injector data from one single source. Take any 3 people doing the conversion and they will come up with different numbers, so if you use part from this one and another part from that one, you might as well just fill in random numbers.
    If you built that VE table based on collected data, one of 3 things is happening - 1, the wideband data is wrong; 2, injector data is wrong; 3, your fuel pump has shit the bed.
    Or, well, one of 4 things - 4, the way you're collecting/applying the error data is wrong. The first file you posted is still in MAF+VE blended mode. To tune the VE you have to fail the MAF and make 100% sure it is running in speed density mode. To tune the MAF you have to put it in MAF-only. To get valid data out of the wideband you have to 100% make sure it's in open loop (because you have set it that way, not because it has O2 faults) and that all trims are reporting 0.00%.
