I purchased an 0411 computer with a base tune and when I got it installed the trans would not work properly. I ended up buying hp tuners and quickly realized that the tuner had the wrong trans selected in the tune. I have changed the trans in the tune and changed the gear ratios and the trans will shift now but it doesn't seem exactly right. Could someone please look at the tune file and see if there is other changes that need to be made. I know that there is a lot of tuning that needs to be done, just want to make sure the basics are there for the trans to function properly. The trans is a 4l80e and the tuner selected 4l60e.
My truck is a 2000 Chevy k2500 with a 383 stroker, tuned port injection, 0411 upgrade, long tube headers, dart heads, comp cams 262/264 duration .450/.480 lift roller cam
