Yeah, it almost sucks starting out on something like that.. starting out on a truck with some long tubes or something it's a lot harder to break anything. I know the feeling.. first tune for me was C6 corvette w/supercharger lol
what is the mods on the car?
93 Ranger. 5.3 D1X. 1069hp.
Is the stumble only present on E85? You've got the usual hack E85 timing tune...
~Greg Huggins~
bt stage 3 cam, ported blower, snout, tb, etc, 2" headers, and e85, manual transmission car
no its present with pump gas also was worse on e85 have it running much better now after cleaning up the VVE tables, gonna throw new plugs in it next week then fine tune it more
I am absolutely not a tuner...ok, got that out of the way.
I was looking at my tune, and that of a friend, and I noticed I have a lot less ignition lead. I know I am making more boost, have ported heads, and headers. He has a slightly bigger cam.
I'm on 91 octane, he's on 93 octane.
OK, I can see how 6 degrees more timing might be doable...again, I have a lot more boost.
But then I looked at his low octane table, and it matches his high octane table. Is this really what you want?
He does not race his CTS-V, just street, so he's not after a time, or trying to beat out his friend. We are 2500 miles apart, so we aren't racing each other, either.
High Octane Table.JPG High Octane Table
Low Octane Table
Thoughts?
No you don't want the timing the same in both tables - needs to be less in the low octane table for safety - otherwise engine will have no ability to save itself if bad fuel such as your 91 or 87 is ever purchased...
Timing also typically shouldn't be the same at a 1 airmass as a full boost 1.26 airmass level...
With 91 octane you may not be able to add that much, but a couple of degrees can make a substantial difference sometimes on these motors...
~Greg Huggins~
~Greg Huggins~
For the record, @gmtech16450yz called me out on the other forum...mentioning my utter lack of activity within these cyber walls.
It's because I don't have any competence, I mean confidence, in this. I can deal with a Holley and distributor fine, but...well, honestly, it's the fact that my car is boosted (16 psi, or 215 kPa, or something like that) that causes me to pause and not load any changes to my tune.
OK, whining over...
Check out my V8 Sky build video. It's pretty cool!...
https://youtu.be/2q9BuzNRc3Q
https://www.youtube.com/user/gmtech16450yz
Do I have to start banning people?
Just kidding of course. Carry on
People really don't busts peoples balls over here very much unless you just flat out ignore what people are asking for or what they're saying you should try.. eventually that does get old, but otherwise I've seen quite a few horrible tunes/logs posted and people usually just try to help
for tuning purposes i can see the matched ho and lo tables, but not for a final version. the room for error is too great in some fuel supplies. 2 degree's on an lsa could mean a 20hp/20ft lb gain depending on where it is.
