Page 6 of 6 FirstFirst ... 23456
Results 101 to 111 of 111
Thread: E38/67 Custom OS Addition?
  1. #101
    Jun 2008
    Charleston, SC
    969
    no, just redownload 2.24 on the homepage
  2. #102
    Oct 2008
    Mebane NC
    475
  3. #103
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,863
    Quote Originally Posted by Chris@HPTuners View Post
    The current plan is E38 (about halfway thru), E67, E78 (complete), E39 (complete). I can do E40 as well if people want it.
    So about those E67s and E40s...
    http://www.dsxtuning.com
    Just say no to bull s***.
  4. #104
    Sep 2008
    1,668
    I was hoping to play with this in a friends TBSS, E67 OS ID is 12611938.
    Stock.hpt
    2023 Durango Hellcat
  5. #105
    Cape Coral, FL
    99
    cool stuff
  6. #106
    Tuner openwheel25's Avatar
    Jun 2011
    Lawrenceburg Indiana
    94
    The output signal from the sensor is a 0-5v square wave.
    So the power wire on the sensor needs 5volts not 12volts? I just bought a sensor and plan on making my car flex fuel.
  7. #107
    Jun 2011
    94
    To answer my question if anybody else would like to know. The flex fuel sensor needs 5 volts on the power wire, chassis ground to the ground wire and the sensor wire to pin forty. On the e38
    I would like to thank everybody for this tread. I wanted to change my car to flex fuel and would not been able to make it happen if it wasn't for the people on this forum.
  8. #108
    Mar 2008
    St. Louis, MO
    4,863
    The sensor takes ignition voltage. It may operate on 5v but GM always wires them to ignition.
  9. #109
    Jun 2011
    94
    I wired it to a 5 volt source. The car has e85 fuel in it now. So after I had the sensor hooked up I looked at the scanner and it said the alcohol percent was 80%. So I thought it was working. Do you think I should change it to switched ignition 12 volts?
  10. #110
    Mar 2008
    St. Louis, MO
    4,863
    It may not matter. All the sensor does is pull the signal to ground. I use ignition voltage because that's what GM uses, and I've seen the sensor have a hard time pulling to ground when run on 5v.
  11. #111
    So bringing this way back from the dead, lol. I have a 2007 CTS-V (E67 - 12609051 OS) that I'd like to run flex fuel (doesn't seem like all the flex fuel options are on this OS), and raise the maf table limit. Currently running a 402ci with an LSA blower at 11psi and it maxes out the maf table (12,200Hz) at 5500rpm. Now I've tuned around it for the time being, but I'd rather it work correctly.
    Question is, is there a compatible OS I can flash onto this car with the parameters I need, or is there a possibility of custom OS features for this? I've tried searching for quite some time, but I haven't seen much info on the CTS-V OS compatibility.
    I've attached the stock tune for reference
    Thanks for any help.
    ~Chris
