I just spent 6 hours tuning a heads/cam f-body with 42# injectors. The car idles perfectly and LTFTs around -5. BUT, under throttle the histogram is full of -12s everywhere. MAF hooked up or not. :-/
I made changes to VE by adding the histogram values to VE. No change. None at ALL.
I tried adding and subtracting varioius percentages from VE. No change.
I tried scaling the IFR up a bit (48.83) without change.
I tried scaling the injector offsets by 10% either way. No change at ALL.
I tried scaling the MAF table up and down with no luck.
The car has a loose torque converter in it which means that the slipping stall keeps the car in the same area of the histogram the whole time.
It seems that with the MAF disconnected, it not running off the VE table. Is it running off Openloop F/A? :huh2: I got the light for the MAF.
