Results 1 to 6 of 6
Thread: INNOVATIVE LC-1--- PAGING KEITH!!!
    Aug 2004
    43
    Looks like Innovative is comming out with the LC-1, wanted to know if it would work like the LM-1, without the screen that they supply. any reason I wont be able to use with HP, to log wideband AFR, and histograms????
    Aug 2004
    Tallahassee, FL
    45
    Re: INNOVATIVE LC-1--- PAGING KEITH!!!
    id like to know too, im looking to get the lc-1 as soon as its released (feb 25 supposedly)
    2001 Z28 (slow)
    Nov 2002
    477
    As long as it will output 0-5 volts and is configurable for what that output represents I don't see why it wouldn't work
    From Innovates Message forum:
    2 programmable 0..5V outputs. Also has 2 serial ports for external logging for LogWorks 2.0. With the serial ports multiple LC-1's (and an LM-1 if so desired) and Auxboxes can be daisy-chained for up to 32 channel realtime logging with LogWorks 2.0.
    http://www.innovatemotorsports.com/f...ead.php?t=1056
    so sounds like it has programmable outputs (2 of them, so 1 could be fore HPT and a 2nd for a Wideband Gauge) which is what HPT needs...
    I'm probably going to try one mid march
    Mike Horist
    00 WS6 (TA) | 04 WS6 (GTP Comp G)
    Mike \\#at&\\ horist \\&dot$\\com
    BOTH cars HP Tuners Tuned
    Aug 2004
    UCSB-Chemical Engineering
    171
    just wondering if anyone has an update on this?
    98 Camaro, M6, HPTuners, heads and cam
    28,314
    considering it hasnt shipped and hptuners is in no way(that i know of) associated with innovate go by what you hear at this point
    so long as you tell us the AFR-V curve we can add it as natively supported or you can confgure it manually, checking the "Is Wideband O2" box will allow it to be used for the histograms.
    I count sheep in hex...
