I was out all day 80 miles total. tuning using the open loop, wideband, AFR error method. I have a large area that is rich and another that is lean. No matter hom much I have changed the VE table it makes no changes in the effected areas. I even went back to closed loop and my LT/ST's are mimicing the AFR error logs. To put it into perspective I looked at the first log I made and the last. in cell # 2800rpm X 40kpa in the error histogram the first was
-19 the last was -20.
Now in the VE table I started out the day with the value in that cell @ 60. By the end of the day it was down to 30. So I cut the value from 60 down to 30 and the air fuel error stayed the same.
Bill I dont know if this is realated to the other bug I have with the boost enrichment?
