FIGURED IT OUT, IM AN IDIOT
You cant see the timing adders in the log nor cyl/air so hard to see exactly where its getting it all from
Factory Stock 97 SS M6 13.51 @ 104.3 mph
Stock Longblock LS1 w/ 233/238 P.S.I. Cam
10.81 @ 126.9 Full interior, six speed on 275 radials, a decade ago
'99 TA trunk mounted 76mm 6 Liter
9.0s in '09 @ 153 MPH
Turbo 5.3 Volvo 740 Wagon
32psi and still winding out 5th on the highway somewhere
I guess you're seeing something that I'm not. You have 73% alcohol so you will be getting roughly 75% of the adder table (12635) based on the way you have your fuel composition table setup (12636). Which should be about 4 degrees up top.
