Hi all
Newbie to the whole tuning thing
Will be doing a Camaro SS(2012) n/a with HP pro, just need to decide on the wideband to go with it
Unlikely to use leaded(apparently NTK sensor is better with leaded or metahnol),
hopefully I will use the wideband on other projects in the future
As far as I understand, the only difference between the AEM 30-0333 X-Series Wideband and the 30-0300 is the OBD; which has the 2 CAN wires
- What is the use for these CAN wires(I understand what is CAN)?
- Can I use it the wideband while this OBD connector is unplugged( I guess yes)?
- Apparently the 30-0300 comes with the harness that includes the 5v signals while the 30-0333 doesn't, which makes the 30-0300 the better option to be used with the HPtuners pro?!
or does the X-gauge now put the data on the CAN and the HPtuners get it from there? I inderstand that speed of the HS GM LAN is 500kbps, but does the HPtuner get it at the same speed or there is delay that kills all the pros of the -claimed-quickest responding sensor?
Your help in clarification is highly appreciated
Inspiro
