Page 12 of 13 FirstFirst ... 28910111213 LastLast
Results 221 to 240 of 251
Thread: VCM Suite 3.4 is here!
  1. #221
    EEC-V support estimate?
    Any ideas on when EEC-V is going to be supported so I can get some people off my back lol? I've seen some posts from the last couple years saying it was coming soon, just wondering if there is an ETA on it. Thanks!
  2. #222
    28,287
    No ETA.
  3. #223
    Baltimore, Md
    1,213
    Quote Originally Posted by wasyl View Post
    well realtime tuning on almost everything, from VE/MAF thru Spark, Throtle Body, IAC, all sensors, spare ports, flat-shift, launch control, external sensors and lots more. Auto-tune feature is excellent to. You can give me any car fitted with MS2/3 and WB02, and i'll tune it within max 2 hours. As for knock sensors they actually work. Also MS2/3 uses CAN, with additional boarda You can control trans stuff, make own ralay board. And tthey are still expanding it with new features.
    best regards
    Give me a stock ECU and can do the same thing?
    9.0s in '09 @ 153 MPH
    Turbo 5.3 Volvo 740 Wagon
  4. #224
    Banned
    Jul 2015
    Poland (Europe)
    174
    i MS comes clear no tune at all ...
    best regards
  5. #225
    Tuner Monty's Avatar
    Apr 2012
    173
    Is the https://www.hptuners.com/customers/d...&build=release from the customer center closed at nights ?
    every time i try to download 3.4 from my customer center download current build 3.4 tab it just sends me to a blank page that never loads..
  6. #226
    Apr 2012
    173
    FIXED Thanks that was fast
  7. #227
    Noob here. Quick question, how do you view and clear DTCs on version 3.4?
  8. #228
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Connect to vehicle
    Go to vehicle, diagnostics and info
    Read, clear, etc.
  9. #229
    Mar 2017
    New updates are great! Any idea when we will have the skim removal option added for Chrysler vehicles? My shop does lots of swaps and we are tired of buying pcm's that people have done this for us. Thanks
  10. #230
    Oct 2014
    10
    no it is not working right
  11. #231
    Oct 2014
    10
    3.4 has issues real time tuning not working right
  12. #232
    Oct 2014
    10
    how do we go back to 2.24
  13. #233
    13,585
    Maybe if you explained the problem(s), someone could help you more. Just saying it doesn't work isn't helping anyone. You wouldn't just walk into a shop and throw your keys at some and say fix it and walk out.
    2.24 is no longer supported, there is no going back.
  14. #234
    Oct 2014
    10
    what is wrong with 3.4 real time tuning
  15. #235
    Oct 2014
    10
    well my real time tuning does not work when you start it with scanner running scanner freezes up any thoughts on this
  16. #236
    Sep 2002
    Chicago, IL
    6,397
    Quote Originally Posted by powerking View Post
    We fixed a bug recently in the beta that may improve real time tuning. Contact support and request the beta. Let us know if it works better for you.
    We got this guy Not Sure, ...
  17. #237
    Jul 2015
    925
    Quote Originally Posted by Jay@HAP View Post
    Attachment 65626
    Will do. "inverse table" may be the wrong way to describe it, I believe I should have used axis instead.
    On a Dodge, when I change injector data or manipulating fueling I change the InjPW vs Fuel Mass table and the Fuel Mass vs. InjPW table.
    After making changes to the injector pulse width in the InjPW vs Fuel Mass table, I would open up the Fuel Mass vs. InjPW table, click on the InjPW axis and paste my changes from the first table then compare them (like in the pic).
    Before 3.4, the InjPW axis data would display in a column which made it very easy to compare it to the other table. In 3.4 the axis is displayed in one row with the graph.
    I hope this explains it a little better.
    Quote Originally Posted by Keith@HPTuners View Post
    You can still do this.
    Copy the axis, paste it in... copy the other axis, paste that in..
    Yeah I get that. My complaint is how it's displayed.
    Thanks.
    Ok. So you want to be able to view it in a single column, instead of a single row. Is that correct?
    Do you know if you guys will ever change this back to the way it was prior to 3.4?
    Thanks.
  18. #238
    Sep 2002
    Chicago, IL
    6,397
    It's unlikely we'll change it back.
    What's more likely is we'll implement some way for you to change your viewing preference. No timeline on that though.
  19. #239
    Tuning Addict
    6,855
    Timeline on 3.6?
    I'll test the new Ford stuff if you need a tester Got one should be ready this Friday
    Oh and so far the beta's re-sync fix for the scanner is working flawlessly other than a minor hiccup along where data freezes for a second - has really allowed me to expand my scanner functionality - Thank You very much Keith... Fixed all of the problems the older laptops were having too - very nice...
    ~Greg Huggins~
  20. #240
    It would be nice to have a feature when you read a vehicle to upload it to the Tune Repository. Looking at other tunes helped me greatly when piecing together all the updates for the E92/T43 ECUs (They finally fixed majority of my rough engine idle / tranny issues with the 6L80e in the 2017 GM Sierra). I've been meaning to upload my stock tune for about 6 months now
