v3.0 HPT doesnt show the readiness monitors anymore, whats the deal with that?
Need to get them to set, what are the drive requirements for it to go through its checks?
Factory Stock 97 SS M6 13.51 @ 104.3 mph
Stock Longblock LS1 w/ 233/238 P.S.I. Cam
10.81 @ 126.9 Full interior, six speed on 275 radials, a decade ago
'99 TA trunk mounted 76mm 6 Liter
9.0s in '09 @ 153 MPH
Turbo 5.3 Volvo 740 Wagon
32psi and still winding out 5th on the highway somewhere
You loaded this tune and have what monitors not ready? Is Cat Monitors OK? Generally speaking there is a table what codes should be passed before every particular monitor set Ready. Cat Monitor consists from only P0430 and P0420 and in your case you should have cat monitor Ready, because you turn them to No Error Reported, which mean they pass
Set all emission codes to do not report. Voila, instant "ready" for all emissions monitors. Change back to previous settings afterwards.
(or at least that works on gen 4's, I'm assuming it's the same on gen 5's)
Tuner by night
CPX Tuning
2005 Corvette, M6
ECS 1500 Supercharger
2007 Escalade, A6
Stock
I'm not sure if it's available for your vehicle or not in the scanner, but to see what's passing and what's not passed - connect scanner to vehicle - DO NOT start scanning - go straight to check engine and scan for codes - what's passed or not passed should show up in the bottom box...
This is just incase you didn't know how to check with this scanner and that's if it's even available for this particular vehicle yet or not?
Hope this helps...
~Greg Huggins~
