Page 20 of 30 FirstFirst ... 10161718192021222324 ... LastLast
Results 381 to 400 of 581
Thread: AEM 30-0300 Wideband with direct CAN integration W/ VCMScanner. Need beta testers.
  1. #381
    Oct 2016
    5
    Analog
    Well, analog it is. Thx guys for the support. I installed the gauge a few mths back. Fighting with it since. Need to get this tune done. Built an engine up last summer and been running it with the ol hypertech. But that's not ganna help with all the mods and changes. I'll wire that up this week and see if I can get her going. Thx again
  2. #382
    Oct 2016
    5
    She's all together and operational. Moved the CAN wire pin positions to the analog output in the back of the gauge. Cut and soldered those to the interface wires. Reading on HPT, and faster then I thought it would. Thx again fellas.
    Now I can get my pos 5.3 build working right
    03 silverado, 4.8 into a 5.3, ls2 cam, 243 port/polished heads, flat top 10:1, tbss intake/tb mod (ported), headers intake exh ext..... 250k miles
  3. #383
    2,821
    So am I reading that Hptuners dropped support of this working in Gen 3 non CAN cars? If not what do I need to do to use it on non Can cars?
    Tuner at PCMofnc.com
  4. #384
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    They never supported it on non CAN vehicles
    Basically need to add two pins to the connector on the gauge to give it a 0-5V out. They're like $0.05 at digikey. Details are in the manual for the 30-0333 model
    You HAVE to use both wires, not just the + side. The ground is dedicated just to this circuit; using the ground everything else in the car is using doesn't work
    Also, the analog out is much faster than the serial out on these and I literally had to go to like 3 decimal places to find any differences between that and the reading over the CAN bus. It was amazingly fast and accurate for me.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
  5. #385
    Tuner gmonde's Avatar
    Nov 2015
    farmington ct
    153
    I don't have the 30-0333 yet and what I have picked up is the lamda format is only talked about but ,is their a way to get Air fuel ratio format to read on the scanner or is the lamda format the only way?
  6. #386
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    You can make it display "afr" based on a few different stoich values
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
  7. #387
    Dec 2010
    Richmond, VA
    40
    I wonder if this can be made to work with a non CAN bus pcm.
    I tested it on my C5 corvette and with a terminating resistor jumped between the can pins on the factory obd2 plug I am able to get hptuners to read the can bus output on the wideband, but it will not read any pcm signals. If I unplug the resistor it reads the pcm, but not the wideband. Why can't it read both when the resistor is installed?
    It seems that this can easily be fixed with programming.
  8. #388
    Senior Tuner 10_SS's Avatar
    Mar 2012
    Detroit, MI
    1,320
    probably because the resistor is shorting out the non-CAN PWM signal? I assume it's PWM, whatever it is. What you could do is change the value of the resistor maybe you will find one that works with both.
    ZL1 Wheels/Tires
  9. #389
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    If I remember correctly HPT only tries to use one or the other protocol, not both, since that isn't something that would "normally" happen
    I don't remember the specifics but I do recall it being brought up when the AEM CAN bus WB's were first released and there was not an ETA for getting them working on non-CAN bus vehicles for this very reason
  10. #390
    Dec 2005
    604
    Not quite. It's a matter of the interface only expecting to see one type of protocol. If it gets a valid response to a CAN request, it doesn't bother trying to search for an J1850 PWM/VPW protocol.
    CAN seems to come 1st in the search order. The 30-0333 produces a valid CAN response. So, it stops there. And, all you will see is the wideband.
    I'm kinda hoping this can be fixed soon, myself. I have a couple of new blower pulleys for my '02 2500HD 6.0L ( J1850 VPW ) and I have the standard interface
  11. #391
    Dec 2010
    Richmond, VA
    40
    Quote Originally Posted by dr.mike View Post
    That is exactly what appears to happen. Seems like some simple programming changes. Please make this change for us Hptuners!
    SHUETUNING
    Powertraincontrolsolutions
  12. #392
    Apr 2008
    Sun Coast, FL
    36
    I case y'all didn't know, Dr. Mike rocks!
    2005 GTO A4 - Crate LS3 480HP - 3200 stall
    1999 SIlverado A4 - 6.0 LY6 - 4l70e - 2800 stall - 4.10 Locker
  13. #393
    Dec 2015
    Wy
    9
    Quote Originally Posted by sohc_mshue View Post
    + 1 on that. Switching back to analog on my swap for now, and moving the CAN gauge to another vehicle, but this would sure simplify things.
  14. #394
    Subscribing...
    I've got two installed, one for each bank:
    Trying to set them up in HPT.
    Will let you all know how it goes....
    2010 Camaro SS 781rwhp
    TKR Stage 4 CTSV 6L90
    Circle D 258mm 3400 3B Pro Series Multi Disk
    Kooks Ceramic LT's & full 3in exhaust
    TFS GenX 255's (Polished PAC .660's and Ti-Retainers)
    TSP VVT 3.2 cam
    Smith Bro's trunnion kit
    AEM X-Series OBDII Wideband Gauges
    FIC ID1300x Injectors
    ZL1 Fuel Pump
    DSX Flex Fuel Kit / Auxiliary Fuel Pump Kit
    MM Camaro 5 Wild
    Holley Tall LS Valve Covers
    NGK Iridium IX #7
    HP Tuners MPVI2+
    ProCharger D1X @ 13psi
  15. #395
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Should work great. Ensure that you change the address and PID for ONE of the widebands. Otherwise you have two devices trying to use the same address and PID which won't work correctly. The directions on how to do that are included in the instructions from AEM.
  16. #396
    I got them on their own addresses.
    Here goes a log:
    Log_07_16_17_89F-1.hpl
    Channels_07_16_17.Channels.xml
    TSP VVT 3.2 cam
    ZL1 Fuel Pump
    MM Camaro 5 Wild
    NGK Iridium IX #7
    HP Tuners MPVI2+
  17. #397
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Looks like they're working well to me. Are you having trouble adding them to charts/graphs or anything like that? Make sure you do NOT use the generic sensor option when prompted for this one..
  18. #398
    Would love to add them to the virtual gauges.
    It's too hard to see when its at the bottom in lines.
    If you know how, and have time, get me the step by step how to for dummies.
    TSP VVT 3.2 cam
    ZL1 Fuel Pump
    MM Camaro 5 Wild
    NGK Iridium IX #7
    HP Tuners MPVI2+
  19. #399
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Post your current layout and I'll do it
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
  20. #400
    07_17_17.Channels.xml
    07_17_17.Layout.xml
    TSP VVT 3.2 cam
    ZL1 Fuel Pump
    MM Camaro 5 Wild
    NGK Iridium IX #7
    HP Tuners MPVI2+
