Stock fuel system
What power have you seen on stock injectors/pump and at what boost, air/fuel A6 or M6 car?
Have one only making a little over 500 rwhp (A6) car at 11.6:1 a/f. 120+% duty cycle, 10.5 psi, fuel pressure data shows falling to 50 psi
Also Im seeing IAT2s as high as 180s
If your at whatever optimal timing is say (probably 20-23 degrees on something making mid 500s since they make up to 25 stock) how much do you really need to keep it happy at 140 IAT2, 180 IAT2?
