Results 1 to 6 of 6
Thread: How to tell if a file is Drive by Wire or Cable?
    Apr 2004
    Erie, PA
    464
    Hello,
    I'm trying to help a guy out with a unique combo, 5.3L with drive by wire throttle body, 4L60E tranny in a 1985 C4.
    How can you tell if the file is cable throttle body or drive by wire? Where in the file does it say it?
    I've attached 2 files that are in question.
    Thanks in advance....
    Bill
    2001 Camaro SS M6 - 23,xxx Miles
    Huron Speed AC Turbo AC Kit - 6.0L 9.4CR, LS3 Heads, 226 232 115 lsa cam, Turbonetics 7575 1.15 AR Turbo
    10.98 @ 133 MPH on 9 lbs boost
    405
    2,329
    System>General>System Options
    Apr 2004
    Erie, PA
    464
    Thank you!
    Sep 2015
    31
    Exactly which one tells you its DBW or DBC? and does ETC stand for Electronic Traction Control in this table?
    May 2010
    Behind the wheel
    272
    The ETC column which stands for Electronic Throttle Control.
    Sep 2015
    31
    I was hoping it was that simple, Thanks for the confirmation!
