Hello everybody!
I'm from Germany, please excuse if my English might not be perfect... I'm tuning my Vortech supercharged C7 (LT1 engine) at the moment and I realized a problem that I can not solve by my own. I tried a lot of changes in the calibration, but nothing helps:
The direct injectors won't open more than ~50%. No matter if I command an WOT AFR of 12, 11 or less than that, the volume of fuel does not increase above a certain rpm and the injectors run into a plateau at 50% duty cycle. When I comand an AFR of 12 (which the C7 likes much more than richer mixtures), than the fuel is just to be enough to meet the required quantity so that the measured AFR can follow the commanded AFR until it hits the RPM limiter. But when I command less than 12 for WOT, you can see more and more that there is a limit at 50% duty cycle. That isn't a problem right now for the 5psi of boost at a WOT AFR of 12 that I'm running at the moment (~630hp at the crank), but I want to increase the boost and will need more fuel soon...
Did I do something wrong? Did I forget to tune a certain map? Is there somewhere a limiter in the software that I need to switch of? Or is the fuel system of the C7 simply maxed out at this level? I can't believe that because I've heard of supercharged C7's with LT1 engines making 700hp at the wheels.
Here is a screenshot where you can see the 50% duty cycle plateau in the top chart:
You can see in the second chart that I command an AFR of 11, but the measured AFR is not able to follow it (it's not my MAF table, that's calibrated perfectly) and stays at 11.8, the AFR error rises and the injectors show a 51% duty cycle in the upper chart which remains at this value.
Please help me! Thank you a lot!
René.
