Page 4 of 4 FirstFirst 1234
Results 61 to 65 of 65
Thread: 10-11 V6 Camaro support, why not?
  1. #61
    28,268
    Vortec
    16258745
    Dodge
    05030232AE
    I4 512k os 16250871 receives VATS Fuel Cut B switch
    P12 pcm’s receive
    To and from cobalt ss/sc unable to connect error fix
    E77/E69 pcm's receive
    Several overboost/underboost condition diagnositic test tables and constants
    Map sensor tables
    Wastegate & BOV tables
    Fuel pressure tables
    Injector tables
    Fan tables
    Spark tables
    512kb & 1024kb LS1 platforms received
    Options matrix
    Platform type switch
    Fan recirc switch
    TPS High & Low fail constants
    About a dozen new rolling idle tables and constants
    IAT Scalar table
    512kb LS1 pcm’s received
    Cranking spark table
    9375577 received TPS High & Low fail constants
    os id 12212156 received
    Upshift D2 2nd
    Downshift D2 2nd
    Upshift D2 3rd
    Downshift D2 3rd
    Following os id’s received Impact factor gain vs airflow, fuel on wall exp decay mult vs airflow, transient fuel min rpm, transient fuel max tps, min fuel milligrams & fuel from wall stabilization
    12579405
    12216125
    Following os id’s received fan desired% v sect & dfco tps minimum
    12579405
    E38 & E67 pcm’s received
    Roughly 50 new tables described here http://www.hptuners.com/forum/showthread.php?t=28498
    The following E38 os id’s received 1-2.5 bar vcm enhancement:
    12612381 12639270 12633056 12635863 12605732 12614676 12612281
    12617631 12628990 12624402 12633016
    E38 Starter check patch applied to:
    12614676 12614088 12630501 12605732
    12615493
    E37 Starter check patch applied to:
    12618032 12618044 12610011
    E38 P2101 Throttle parameters added for
    12617631
    All E38 operating systems receive the following speed limiter constants
    Speed Limiter 4WD Low
    Speed Limiter Comms Fail
    Speed Limiter Steering Fail
    Speed Limiter Minimum
    Speed Limiter ETC Fail
    E67 OS id 19211212 received 1-2.5 bar vcm enhancement addition
    E67 pcm's can now perform write calibration only without error
    All E40 os’s receive cranking spark table
    E40 os’s 12596734 & 12596660 received
    P2101 Throttle tolerance params
    T43 TCM's received a major 150+ table update including TM & TCC lockup tables requested
    E37 support released
    GMPP E67 pcm support released
    GMPP EROD pcm support released
    2009+ Allison TCM support released
    2010-12 Camaro V8 ECM/TCM support released
    2009-12 Corvette ECM/TCM support released
    2009-10 Mustang V8 ECM support released
    2009-10 Savana/Express V8 gas support released
    2009 G8 V8 support released
    2002-2011 Ford BA, BF & FG support released
    2009-2012 Escalade ECM/TCM support released
    2009-2012 Silverado/Sierra V8 ECM/TCM support released
    2009-2012 Tahoe ECM/TCM Support released
    97-04 V6 pcm’s
    Received several open loop and injector tables added to all 700+ operating systems
    Ford credit licenses lowered to 2 credits for single vcm licenses
    Ford Scanner rate updates for faster scanning
    Fixed airflow table address in Aust. Ford operating systems HAEDG/HADCK
    Raised upper limits on pulse width min constant
  2. #62
    Advanced Tuner BigDaddyCool's Avatar
    May 2009
    Brisbane, Queensland
    767
    Ashame no E55 controller gear....
  3. #63
    Jul 2011
    28
    So when will 2.24 be finished..oh sorry
  4. #64
    Sep 2011
    ive read this whole thread and joined this forum just to let you know that there are a lot of v6 owners out there that want a tune and there are a lot of tuners that want to be able to tune our v6's with your product... I understand how you might feel that the demand isnt as high as the v8's but i dont think that is on point. We v6 owners are waiting (the ones who havent gone to "trifecta") for your tune to be released... Im not knocking you guys at all and i am def waiting for your tune, but you gotta stop givin some of the posters a hard time for asking and asking about dates and what not... the people that are trying to develop cam shafts for us are gettin the same questions as well.. i desperatley want/need the tune.. ive recently added a nitrous system along with some other performance upgrades but really neeed the tune to set it off... PLEASE PLEASE understand that we just want your tune and not get mad when we show our interest....thanks
  5. #65
    I'm gonna close this thread guys as it has run its course, the answer is clear it will be looked at after 2.24 is released. There is no question on demand, we have already decided yes.
    Chris...
    I count sheep in hex...
