Page 1 of 3 123 LastLast
Results 1 to 20 of 59
Thread: New E38/67 params coming soon
    Guys,
    Some new E38/67 params that will be coming over the next couple of months.
    Chris...
    Idle
    - Idle adaptive max VSS
    - Idle adapative max VSS - hyst
    - Idle Percent Area Max
    - Idle Percent Area Max (brake)
    - Idle RPM Max
    - Idle Overspeed throttle closed delay
    - Idle Underspeed throttle closed delay
    - Throttle Follower Torque
    - Throttle Follower Torque (4wd Lo)
    - Throttle Follower Step Down
    - Throttle Follower Step Up
    - Throttle Follower Airflow Max
    - Idle Trans Drive Airflow
    - Idle Trans P/N Airflow
    - Idle Trans Drive Airflow Step
    - Idle Trans P/N Airflow Step
    - Idle Trans Drive Hold Time
    - Idle Overspeed Error Mult
    - Idle Underspeed Error Mult
    - Idle Overspeed Startup Airflow Time
    - Idle Underspeed Startup Airflow Time
    - Idle Integral Airflow Limits
    - Fan Low On Airflow
    - Fan Med On Airflow
    - Fan Hi On Airflow
    - Fan Low Off Airflow
    - Fan Med Off Airflow
    - Fan Hi Off Airflow
    Closed Loop Fuel
    - Integrator Delay vs Airflow Mode
    - Proportional Base
    - Proportional Gain
    - Proportional ECT Mult
    - Proportional Limit
    Spark
    - Minimum Final Spark
    - Minimum Final Spark Reduced Power Mode
    - Minimum Final Spark TqMgt
    - Bidir Retard Max
    - Spark Airmass Multiplier
    Electronic Throttle
    - Desired Throttle Area - A
    - Desired Throttle Area - B
    - Desired Throttle Area - C
    - Desired Throttle Area - D
    - Desired Throttle Area - RedPwr
    I count sheep in hex...
    woohoo! looking forward to the minimum final spark.
    thanks... and hurry up.
    2017 camaro ss a8 with low mount twins
    Nov 2006
    2,735
    Man, I would love these for Gen 3 stuff!
    Good work guys!
    Tuner at PCMofnc.com
    Advanced Tuner Bluecat's Avatar
    May 2006
    Catlettsburg, Ky
    407
    It's like Christmas in March...
    Thanks guys.
    Good work guys!
    the throttle cracker speeds do this for the LS1.
    Feb 2010
    SLC, UT
    47
    Any ETA on this?
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,265
    probably 2-3 weeks while our engineers add them to the e38 defs
    i've also added some params to control the Alternator, although the BCM does most of the work and the ECM has limited override capabilities it should be fine for those doing engine swaps or transplants.
    Also added some MBT Spark tables.
    Chris...
    Nov 2007
    232
    Does this mean you guys are going back to looking into fueling tables, fan tables, and fixing the issues with the scanner and the LNF?
    "I didn't fail, I just found 100 ways to do it wrong." - Benjamin Franklin
    Senior Tuner Frost's Avatar
    Jan 2006
    Richmond VA
    1,950
    Quote Originally Posted by Chris@HPTuners View Post
    for all GenIII OS's??
    Steve Williams
    TunedbyFrost.com
    Nov 2006
    2,735
    Yeah, seems like I've tried zeroing all throttle follower and throttle cracker (as well as disable it via speed) and adaptive spark and STIT + LTIT go inactive above 1mph. It would be nice to keep all of that active regardless of speed.
    Potential Tuner PowerLabs's Avatar
    Oct 2009
    Ann Arbor, MI
    7
    Can't wait
    Advanced Tuner madvette08's Avatar
    Jan 2009
    Tampa, FL
    427
    Cant wait to, thanks guys .
    2008 Corvette A6 - Comp Cams 231/239 617/624 109 ICL 113 LSA, Patariot Extreme Dual Springs .660", Milled .30" Stock LS3 Heads, Mahle -4cc pistons, FTI 3600 Converter, 1 7/8 kooks cat-less 3 inch X-Pipe, air raid intake, ported TB, SLP Loudmouth I. 512hp/464tq
    2011 Ford Taurus SHO - stock with just a Tune
    Nice, will this roll out with 2.24 or is that different?
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,859
    Spark
    - Bidir Retard Max
    This has my interest peaked. Can we get a screen shot of what the TqMgt table looks like?
    http://www.dsxtuning.com
    Just say no to bull s***.
    Dec 2007
    776
    Has the version with all these additions been cut yet ?
    HP Tuners Support
    (foff667)
    28,265
    No, from what I can tell our engineers haven't started adding them to all of the E38/E67 operating systems yet as it required a new definition editor that was just recently posted for them. It'll likely be a couple of weeks minimum as they have alot of work on their plate currently.
    hoping for an update on this please! Could really use some of these parameters asap!
    HP Tuners Support
    (foff667)
    28,265
    Beta is up for these. Contact support if you would like access.
    hell yeah. new stuff is always cool.
