Looks like Innovative is comming out with the LC-1, wanted to know if it would work like the LM-1, without the screen that they supply. any reason I wont be able to use with HP, to log wideband AFR, and histograms????
id like to know too, im looking to get the lc-1 as soon as its released (feb 25 supposedly)
2001 Z28 (slow)
As long as it will output 0-5 volts and is configurable for what that output represents I don't see why it wouldn't work
From Innovates Message forum:
http://www.innovatemotorsports.com/f...ead.php?t=10562 programmable 0..5V outputs. Also has 2 serial ports for external logging for LogWorks 2.0. With the serial ports multiple LC-1's (and an LM-1 if so desired) and Auxboxes can be daisy-chained for up to 32 channel realtime logging with LogWorks 2.0.
so sounds like it has programmable outputs (2 of them, so 1 could be fore HPT and a 2nd for a Wideband Gauge) which is what HPT needs...
I'm probably going to try one mid march
Mike Horist
00 WS6 (TA) | 04 WS6 (GTP Comp G)
Mike \\#at&\\ horist \\&dot$\\com
BOTH cars HP Tuners Tuned
just wondering if anyone has an update on this?
98 Camaro, M6, HPTuners, heads and cam
considering it hasnt shipped and hptuners is in no way(that i know of) associated with innovate go by what you hear at this point
so long as you tell us the AFR-V curve we can add it as natively supported or you can confgure it manually, checking the "Is Wideband O2" box will allow it to be used for the histograms.
I count sheep in hex...
