Hey folks, got a 2007 C6 A6 with a A&A Vortech S-trim kit-car makes 570 rwhp. Should the trans tune be modded or kept stock-I want to make sure this trans stays together with the added power and torque.
TIA
TIA
GO RAIDERS!!!!!!!!!!
02 C5 Z06
8.8@160
go with the 08 operating system your A6 will like it better.
23 Year GM master tech, Corvette specialist, Owner Blanchard Performance Engineering
You will need to have someone with a tech 2 flash in a calibration.
2008 Corvette A6 - Comp Cams 231/239 617/624 109 ICL 113 LSA, Patariot Extreme Dual Springs .660", Milled .30" Stock LS3 Heads, Mahle -4cc pistons, FTI 3600 Converter, 1 7/8 kooks cat-less 3 inch X-Pipe, air raid intake, ported TB, SLP Loudmouth I. 512hp/464tq
2011 Ford Taurus SHO - stock with just a Tune
Is it possible to copy the 08 trans settings into a 06 VCM?
What are the main changes?
If you compare the 2 files you can copy over the differences in the trans. That step flew out of my mind lol
Ian
