Results 1 to 14 of 14
Thread: Fuel Control
    Senior Tuner Mep_q8's Avatar
    Mar 2006
    Kuwait
    1,564
    Fuel Control
    Taking a look at a friends F150 file, I finally found out how to change the fueling on these vehicles. There's alot more to play with in terms of fueling, but here's the basics.
    Go to Engine - Fuel Control - OL & CL - Fuel Base (Fuel Base vs. RPM vs. TPS) It shows that the fuel is calculated in Lambda's, something which I'm very new too. Did a search on the inet and came up with this table..
    Scroll down to the bottom of the page... http://www.rbracing-rsr.com/rsrgauge.htm (If someone can forward me the code that will just display the calculator in here, I'm sure we could get a sticky done)
    I will be hooking my LM1 up to my friends F150 in the next couple weeks and will start to play round with these tables. I do hope this tables works as accurate as the PE AFRs in the GMs
    Bader Norris
    MEP Tuned
    Telephone: +965-55446651
    Email: [email protected]
    Instagram
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    AFR=Lambda*14.7
    Russ Kemp
    Mar 2006
    Kuwait
    1,564
    Quote Originally Posted by Russ K
    AFR=Lambda*14.7
    Russ Kemp
    Cheers Russ! For some reason i didn't think the equation was that easy
    Bader Norris
    MEP Tuned
    Instagram
    May 2006
    Langhorne, Pa
    102
    Yupyup. Take the value in the table and Multiply it by that.
    Russ,
    I thought I read somewhere that Ford figured Lambda at 14.64.. not sure why. Is this not the case?
    2007 Mustang GT
    266rwhp 276rwftlb's. 13.6@104 stock.
    Adding a bunch of goodies and shooting for mid 12's.
    Dec 2005
    Regina, Sask.
    4,214
    I don't see a Stoich AFR table on the F150. Just did a 2002 Sunfre 2.2 (Stoich was 14.6). Some Gen III V8's had Stoich @ 14.63.
    Scan the vehicle to find out.
    I always change the Stoich to 14.68/14.7 when this table is available.
    Russ Kemp
    Yep all in lambda, not too big of a deal though since it easily converts to A/F.
    Don't rely on that table to tune fuel though.
    Justin Starkey
    Ford and GM custom tuning
    Mobile Dynojet 224xLC
    www.VMPTuning.com
    2006 F250 CC 6.0L 14.3@92
    2006 Mustang 4.0L Vortech 15psi 395rwhp wife's car
    2000 Mustang 3.8L TT [email protected] 450rwhp
    Nov 2007
    232
    AFR=Lambda*14.7
    Russ Kemp
    Now don't you think that depends upon the fuel being used ?
    As an example:
    90% Gasoline 10% Alochol is 14.1 calculated AFR; but, is still 1.0 Lambda Or
    15% Gasoline 85% Alochol is 9.85 calculated AFR; but, is still 1.0 Lambda.
    Also, the base fuel table in the F150s is used when in Open Loop. While in closed loop, the newer F150s will do everything they can to stay at or near 1.0 Lambda for emissions control. The SCT Tuners allow a scalar setting for AFR. The HP Tuners do not. To adjust air / fuel at WOT, use the MAF Transfer table along with the Base Fuel Table.
    Dec 2005
    Regina, Sask.
    4,214
    I was referring to gasoline in post #2. The screen pic is of the stoich AFR table from a 2007 Sierra 6.0L.
    I understand that the fuel base table is used in open loop (when in PE). This table is for setting the commanded Lambda (AFR) when in PE. Then the Maf Airflow vs. Voltage table is adjusted to get the actual AFR to match the commanded. Basically the same way I tune the GM's.
    The fuel base cold is used to command the open loop fueling vs. ECT. GM also has a similar table. In PE, the richer of the open loop table vs. ECT or the EQ Ratio vs. Rpm is used.
    Russ Kemp
    Nov 2007
    232
    Russ Kemp
    Thanks for the clarification Russ. Having worked with the SCT Pro Racer software for 18 months now I look forward to working with the HP Tuner software.
    I have two questions for you. Have you done anything in the F150s with the Electronic Throttle settings ? Ford's factory settings limit us to a Max Throttle angle of 83. I don't have some of the settings shown in the HPT available within the SCT Pro Racer Software; but, I have read references from a SCT Tuner to adjusting these. Also, I am unfamiliar with the acronym "PE" you have used above .
    May 2006
    Langhorne, Pa
    102
    PE is Power Enrichment. Basically, your Commanded AFR at WOT.
    AS for the Mac Throttle, 82 is the max on the mustangs. I don't think it's truely throttle angle per-say, so much as a throttle position.
    2007 Mustang GT
    May 2004
    5
    Quote Originally Posted by schaid
    As an example:
    hi,
    what is the MAF Transfer table, where is it?
    thanks for your help.
    volkan
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,275
    Quote Originally Posted by vtanju
    hi,
    volkan
    Its one of the main fueling tables in any maf enabled calibration basically tells the pcm how much air is coming into the intake at all times.
    Its under Engine-Airflow-General Airflow-MAF
    http://www.hptuners.com/help/vcm_edi...ow_general.htm
    May 2004
    5
    Quote Originally Posted by Bill@HPTuners
    thank Bill
    i know that table MAF airflow vs Voltage table. am i correct? i just got confused when he said MAF Transfer table.
    volkan
    HP Tuners Support
    (foff667)
    28,275
    Maf transfer, maf table, mass air table, etc...all the same, different verbage.
