Page 2 of 2 FirstFirst 12
Results 21 to 33 of 33
Thread: HPT Not working
    Dear,
    passenger side kick panel mini fuse #29(C/LALDL) is blown. replace it and enjoy your tuning.
    I just changed all the 5,10,15,20, and 25 fuses but still no power to the` OBD II port
    ok wait collection some information to send you !
    Quote Originally Posted by vette_doc
    Dear,
    That's in the engine compartment right ?
    I changed it, and just changed it again with a 20 amp, and the power still did not come back
    im reading the owners manual and it looks like there are two fuse boxes.
    wheres the panel bopx. now I feel like a real noob
  6. #26
    pin#16 gets power direct from mini fuse#29, if fuse is ok and not getting power then you have problem with wire from fuse box to ALDL.
  7. #27
    OK im a F-ing tool. I found the second fuse box and pulling the cover now.
    What a tool I am !
    I just hope the fuse is blown lol
  8. #28
    Doc your the man, Thanks kevin also
    Changed out the fuse and it powered up.
    I get the tool for the day award !
  9. #29
    Good luck man, we all are here to help each other.
  10. #30
    Not A Tuner
    Oct 2006
    977
    Tool, Fool ......
    Its COOL you own a VETTE !!!!!!
    DH
    2004 MSG A4
    Appearance: Billet Plate&Sill/SS Insert/Screens/Blackout/Lowered/CCW SP500
    Perfomance: 416 CI/228-232@114/AFR 225/FAST/LS2 TB/36#Injectors/Honker/RPM(IV)/Vig2400/Z06 Ti/Kooks/3.42 Gear/Hotchkis/Bilstein/Z06 Springs/Eradispeed/Hawk HP+/Trans Cooler/B&M Trans Pan/RonDavies with EOC/Nitto R2's/AMWcan/Rocker Rails/Frame Savers
    Mods & Tune: A&A Corvette
    ??? RWHP / ??? RWTQ
    1/4 mile: mid 11's ??
    WSIR 1:37.68
  11. #31
    May 2003
    Santa Clarita, Ca
    962
    Quote Originally Posted by Phil'sC5Vette
    Do you know which fuse it would be in a Y2K C5 ?
    I checked them and they all looked fine
    "Rear Fog/ADLD/TOP SW" ????
    Seems to ring a bell for me on some other GM vehicles.
    -Ken
  12. #32
    which vehicle?
  13. #33
    May 2004
    46
    Exactly the same happened to me. Replaced fuse 29, back and working.
    What caused it was the following: Driving at night. My son connected the MPVI to the OBD II serial connection and I guess in the dark, didn't quite make it. There was a white flash and the fuse had gone. Is there some contact between the serial connection and the MPVI that would cause it to short? Is there a rule that says you should not connect the MPVI when the car is running??
    Tip for anybody replacing the fuse. The spare fuses are in the engine bay fuse box and the SPECIAL TOOL for removing the fuses is here, not in the passenger compartment where the blown fuse is located. Go to the engine bay fuse box first to locate the spare fuse.
