New Performance, Same Proven Workflow.
  • Newest generation hardware platform
  • Dual Core @ 1.7GHz and 1GB RAM for faster processing
  • Improved standalone data logging with more parameters at higher speeds, comparable to VCM Scanner with a wired connection
  • Wi-Fi support (available with future firmware update)
  • New tapered OBDII connector for a stronger, more secure connection to the OBDII port
  • Compatible with thousands of models from 40+ vehicle manufacturers
*Select controllers on MPVI4 such as Ford EEC-V, Mopar JTEC, JTEC+,JTEC+B, and NGC3 will be supported in a future update.
Tune All The Toys In Your Garage
  • Supports hundreds of controllers and thousands of years, makes, and models
  • Works with late-model muscle cars, trucks, daily drivers, and powersports machines
  • Fully compatible with VCM Suite 5.1+ for scanning, diagnostics, and custom tuning
Built for Professionals, Trusted by Enthusiasts.
Whether you tune vehicles for a living or want to optimize your own build, MPVI4 provides the same reliable workflow HP Tuners is known for—now faster, more capable, and ready for the journey ahead.
CA WARNING
WARNING: This product can expose you to chemicals, including lead silicate, which is known to the State of California to cause cancer, birth defects, or other reproductive harm. For more information, go to www.P65Warnings.ca.gov.
WARNING: This product can expose you to chemicals, including carbon black (airborne, unbound particles of respirable size), which is known to the State of California to cause cancer. For more information, go to www.P65Warnings.ca.gov.
WARNING: This product can expose you to chemicals, including nickel oxide, which is known to the State of California to cause cancer. For more information, go to www.P65Warnings.ca.gov.
ATTENTION: This device complies with part 15 of the FCC Rules. Operation is subject to the following two conditions: P(1) this device may not cause harmful interference, and (2) this device must accept any interference received, including interference that may cause undesired operation.
