Hi guys. I have my HPT and LM-1 running but can't figure out why the LM-1 is reading from 3-5 points lower than tuners at all times. I have everything hooked up per Checkmates instructions and the Lm-1 is programmed for 0V-10AFR and 5V-20AFR. I checked my connections and they are ok (not soldered, just twisted and taped). Does anyone have theirs working perfectly? Even at idle when the AFR is rock solid on the Lm-1, HPT is 4 points higher. I also tried to configure my own PID by dividing by 0.5V and adding 10. When I first start the car and the AFR is around 19-20 it looks to be right on but when it drops to 13 is when the offset occurs. I'm having a hard time tuning because I can't trust what I'm seeing in HPT. Any ideas?
