Page 11 of 20 FirstFirst ... 789101112131415 ... LastLast
Results 201 to 220 of 399
Thread: Incorrect / Missing Parameters? Let us know
  1. #201
    Senior Tuner S2H's Avatar
    Apr 2005
    Schexnayder Racing - Arnaudville LA
    4,387
    here you go...
    -Scott -
  2. #202
    Oct 2007
    Crawfordville, FL
    2,412
    Quote Originally Posted by S2H View Post
    noticing on an 07 GT500 that a customer brought in for injectors/gears/tune....
    the Spark Idle Min.... was set by somebody else to -10*
    hpt only allows 0 as a minimum 64 as maximum
    so the range of the parameters is incorrect as obviously it will allow less in the tune.
    I keep finding little things like this. I will correct it tomorrow.
    Eric Brooks
    HP Tuners, LLC
  3. #203
    Apr 2005
    4,387
    I'm sure there are more....thats just one I found that I needed to get this car to idle correctly...
    would not idle down lower than 1200 no matter what I put in for idle airflow.....then I found the file that was originally in it and proceeded to use and modify it because it had a -10 and had zero issues getting down to commanded idle around 700 rpm.
    copied over all of my stuff into it leaving the spark idle minimum at -10
    it started as a file from somebody else, and was on an SCT box...
    I turned it back to stock so they could sell the SCT box...and in the process lost that -10 variable...
    thankfully I read the file from the ECU before returning it to stock.
    -Scott -
  4. #204
    Oct 2007
    Crawfordville, FL
    2,412
    Must have a big throttle body on it?
    Eric Brooks
    HP Tuners, LLC
  5. #205
    Apr 2005
    4,387
    and a big Whipple...
    -Scott -
  6. #206
    Oct 2007
    Crawfordville, FL
    2,412
    Get it right, that's a Kenne Bell! I had that same setup a few years back.
    Eric Brooks
    HP Tuners, LLC
  7. #207
    Oct 2011
    QLD, Australia
    436
    Quote Originally Posted by Eric@HPTuners View Post
    Yes, all the source values will be defined.
    Torque, Spark, Fuel, Driver Demand, Cam, etc. There is a bunch of source flags you can log.
    Awesome! Had epic Failure trying to tune the cams. Toads found some good tables in SCT that worked straight up, ISC integration. Would be a good one to have in HP also
  8. #208
    Apr 2005
    4,387
    whatever...same shit different name
    -Scott -
  9. #209
    Oct 2007
    Crawfordville, FL
    2,412
    Quote Originally Posted by 45T-XR View Post
    It will have all that and then some.
    Eric Brooks
    HP Tuners, LLC
  10. #210
    Feb 2010
    Perth Australia
    480
    ^Wheeeeeeeeeeeeeeen?
    04 Velocity MKII M6 & 06 BF F6 555 ZF6
  11. #211
    Oct 2007
    Crawfordville, FL
    2,412
    I've corrected this in every definition as of 2.24.576
    Eric Brooks
    HP Tuners, LLC
  12. #212
    Oct 2007
    Crawfordville, FL
    2,412
    Quote Originally Posted by hiddeous View Post
    I want it worse than anyone.
    Eric Brooks
    HP Tuners, LLC
  13. #213
    28,272
    Maybe not worse than anyone
    I want it more than you
  14. #214
    Advanced Tuner caesar's Avatar
    May 2003
    227
    This thread is full of desire.
  15. #215
    I tested again on two cars, same calibration. No change in mixture when changing lwfm tables when maf disconnected. And no change when another available airmass tables changed.
  16. #216
    Any news is this?
    Another thing. MAF Temp Compensation, looks it works opposite like it's described. Values from tables are substracted from 1.0 and this gives final factor, not added. So positive values in table makes leaner, negative makes richer.
    Eastern and Central Europe American Muscle and Harley-Davidson tuning
    www.hd-customs.pl
    http://www.facebook.com/hdcustomspl
  17. #217
    Is there any table that correspond for enrichement in cold condition and is hidden?
    I have problems on 2 cars that they are to rich when wot when cold. No problem on N/A cars, due it makes richer from eg 12.8 to 11.5 or so, but when commanded afr is 11.5, it makes something like 9.5 and then it missfire, way to rich.
    I checked all tables available with no results. Airmass tables, transient fuel tables (even zeroed them all).
    Some help makes MAF Temp Compensation, but when car is hot, air temp is still same and then it's to lean.
    It's not injectors related, due one car is dual fuel, and second fuel is doing this same.
    But he don't change commanded lamba, it's cold and hot as set in base fuel table, 0.79.
    I tried also cold fuel table, but car never showed commanded lambda from this table. It always uses normal fuel table, no matter what enable and disable ect is.
    I checked this on 2 cars.
    Looks table like maf temp compensation but in function of ETC could help.
    www.hd-customs.pl
  18. #218
    Do You have any info in my case?
    FYI, i checked another mustang with different calibration and looks its this same, both cases. Enrichement when cold and not possible to change mixture in sd mode.
  19. #219
    Oct 2007
    Crawfordville, FL
    2,412
    I don't totally understand your issue. There is some logic that can take place if the engine speed doesn't doesn't run up like expected, and the RPM adds some additional fuel because it infers that the fuel is of poor quality. There is a switch I can add in so that you can shut this logic off. I have it on my list of things to add.
    Eric Brooks
    HP Tuners, LLC
  20. #220
    First issue, make car running without maf with fuel trims at zero percent at close loop. Car will have no problem with stock cams. But with any others trims are usually more rich at idle. I cant change it with any available table.
    Second issue, kind of enrichement at accel till car warms up. No problem hot, afr on spot. No problems on cold in close loop. Even i disable openloop completly, trims are on spot. Open loop enabled and its much more rich than commanded. Premium fuel 93 octane.
    Same on stock car, but its not noticable, since its not commanded rich. This issue is definitely related to etc not iat.
    Both issues will not be seen in 99 percent of cars.
    Tomorrow i'll have another stock mustang, so i'll do additional checks.
