I haven't yet received them so I don't know. But I'll publish what is sent to me. To tell you the truth, I didn't even know there was a difference until I started researching it after I placed the order.
42# DMI
PFU041-0420
any clues ?
2.4 ecotech ( 2006 pontiac solstice )
42lb injectors
trim 50 garrett t3t4 (custom -barebones pumpking )
boost @ aprox 7 <10
38mm tial wastegate and bov
3" tubes front to back
werks radiator
bell intercooler
GXP,magna flo exhaust-with integrated dumptube by B_FASTER & R&D
aem wideband
custom manifold -by sh**er the skunk
(((HP ))) tuning - in progress
jet hot 2000
aerospace logic egt kit
OK, I received 8 injectors, each with a number written on them in silver Sharpie. Also received a sheet with matching numbers, showing [email protected]/3Bar. The columns are lbs/hour, cc/min, 80% duty cycle (7K RPMs@14ms), and impedance.
The breakdown:
Qty (4): 480cc/min
Qty (1): 481cc/min
Qty (1): 484cc/min
Qty (1): 487cc/min
Qty (1): 498cc/min
Their website (http://www.neweraperformanceparts.com/default.asp?S=503&A=E&PKV=l42fm|0) advertises the injectors as "These injectors are all flowmatched with 1% of each other and come with a flow data sheet."
Nice, drop the fatty in the number 7 hole, and the next one down in the #8...
It looks like all except for the largest are within 1%. They also are a little bit larger than 42.5 lb/hr, with 480cc/min being 45.7 lb/hr. Those are 52lb/hr injectors for the LSx crowd!Originally Posted by JimMueller
I thought 7 and 5 were the leanest cylinders?
Aaron
'03 Z06 Corvette - The Normal Stuff.....
EFI-101, EFI Advanced, EFILive-101, Variable Camshaft Tuning
EFI University Evangelist
Jim,Originally Posted by JimMueller
Do these have a blue stripe at the top? Do they have a part number on them?
Aaron
They have a blue stripe and have two numbers: 01D030B and 3556. I've always heard the cylinders at the back of the engine are the leanest, which would be 7 & 8.
So in the injector spreadsheet, would I average the lbs/hour value for the 'Injector Rated Flow Rate' field - use 46.07??
I would use 45.7 lb/hr @ 3 bar.Originally Posted by JimMueller
Aaron
Are the blue Cobra 39# injectors easy to tune? I figure they'll run a little higher (40-42) at our pressure.
yup, they run fine, i tune them in a 05 gto and they work just fine.Originally Posted by ROCNDAVE
Only issue with them is the spray pattern. It's split so that 1/2 goes down each port of the 4V Ford heads. Probably end up with a lot of port wall spray with them.
Always Support Our Troops!
I was going to use them in my 395 LS1. I have a home ported Fast 90 Intake, NW 90mm TB and AFR225 (66cc) heads. I plan to only run NA.
Is it a better idea to sell these and go with a set of green top 42 lightning / Lucas injectors?
Will the cobra 39#ers support 500RWHP?
If people would only read things lolOriginally Posted by EC_Tune
Sulski Performance Tuning
And somehow I posted exactly the same thing 2x
Having no data that was solid to go by in the past, these were MUCH more of a PITA for me to get straight than the Lucas/Delphis...
