Thread: IF statement syntax
    Aug 2021
    560
    IF statement syntax
    Yeah I should probably post this in the VCM scanner section, but it'll take weeks to get an decent answer there...
    Reviewing the documentation...which does not provide any syntax examples...I cannot get the IF statement to work.
    https://www.hptuners.com/help/VCM-Sc...operations.htm
    How would a fellow create a custom math parameter to do something simple like this?
    IF([4340.91] > 100)
    This is saying if TCC Pressure is over 100 kpa, return a 1, otherwise return a 0
    Whenever I use this it always returns 0
    My Tuning Software:
    MAF Assistant
    EOIT Assistant
    Tuning Addict
    6,882
    You most likely did, but did you try without the parenthesis or putting the whole thing into parenthesis while using it in a different equation?
    ~Greg Huggins~
    Jul 2020
    VIC Australia
    1,196
    ([4340.91] > 100)=1 should do it.
    After updating a math parameter you need to add / delete the channel in the graph to see the change. I just use the duplicate channel button then delete.
    Aug 2021
    560
    Thank you that did it!!!!
    My Tuning Software:
    MAF Assistant
    EOIT Assistant
